Prev Previous Post   Next Post Next
Old 07-28-2004, 05:55 PM   #1
sc2095
sc2095 is on a distinguished road
sc2095's Avatar
Default Weird cooling system problem
I helped my friend replace his waterpump on his 93 SC2 yesterday, cause it finally died. We filled the system back up with water and coolant, and then let it run to check for leaks. It was working perfectly. We went for a drive, and noticed that the car started to heat up, and wouldn't cool back down. We took it home, and everything seemed ok, but when the car was cold, he took off the coolant resevior cap, and coolant came running out of it. He filled it back up to the lower level, and then went for a drive again. The same thing happened, only it took longer for the engine to heat up. Any idea why this is happening? The thermostat is opening up because both radiator hoses heat up and he has lots of heat in the car.
sc2095 is offline
Weird Cooling Fan problem Dime333 S-Series Tech 6 08-05-2009 10:02 AM
Cooling System Problem? kyasarin S-Series Tech 7 07-26-2009 09:14 AM
cooling system refill problem..... plum_sc2 S-Series General 32 01-08-2005 01:09 PM
Cooling System over pressure problem flyingw80 S-Series Tech 22 10-23-2003 11:36 AM
Cooling system problem looneyluden Miscellaneous Tech 6 10-25-2000 07:41 PM
