Go Back   SaturnFans.com Forums > Models > Saturn Ion > Ion Mods
Old 04-06-2022, 01:03 AM   #1
05_ionS/C
05_ionS/C is on a distinguished road
2005 ION-2 Sedan
Default 05 Saturn ion 2.2 l61 build (the journey to 400hp)
So a few months ago i bought a 2005 saturn ion sedan 2.2 l61 auto with full intentions of building it. Yes i know the down falls of it not being tuneable already so no need to tell me about the fact that tbe e16a ecu n stock tcm are not supported by hpt, and trifecta no longer offers tuning for these cars either. Also I am aware of other cheaper options to make more power, but my goal since the day i bought this car was to retain the 2.2 l61 gen 1 engine and make a 400hp street car. But i have the full build planned already planned out other than what i want tl do with the audio system. So the journey for 400hp 2.2 street car begins. Im starting with the under side of the car and full suspension build, brakes, wheels and tires, which i will begin to order Friday when i get paid. Full suspension build plans listed below.
Clean underside of car and paint gloss black with por 15
Clean and paint front subframe illusion purple
Zzp tubular lower control arms powder coated gloss black
Zzp ball joint heat shields powder coated illusion purple
Zzp front sway bar kit
Zzp 140mm adjustable front sway bars
Paint front knuckles gloss black
New Cobalt ss 5 lug front hubs
Zzp 12.25" brembo front brake kit
Goodridge stainless front and rear brake hose kit
Steering rack spacers
New rack and pinion and inner and outer tie rods
Paint rack and pinion and inner tie rods gloss black
Have outer tie rods powder coated illusion purple
Paint front calipers and brackets illusion purple
Ion redline rear axle beam
New Cobalt ss rear 5 lug rear hubs
Cross drilled slotted rear rotors
New cobalt ss rear calipers
Paint rear axle beam illusion purple
Red poly axle beam bushings
Paint rear calipers illusion purple
New Copper coated brake lines
New cobalt ss e brake cables
Zzp rear sway bar kit
New gas tank straps
Bc coil overs
AEM e85 compatible in tank fuel pump
Zzp billet engine mount
42 draft designs 5x110 to 5x114.3 hubcentric wheel adapters
Aodhan ds01 gold 18x8.5 +35 offset 5x114.3ug pattern wheels
Nitto neo gen 215/40zr18 tires with permanent white nitto tire decals
Purple spline lug nuts
Purpme valve caps
Once everything under the car is complete and finished and able to set it back on the ground i will begin collecting all my 5 speed swap parts. Im planning on using a f35 5 speed as i have a line on a full swap for under $200. But i will be upgrading most of it anyway.
Plan for the trans and drive train listed below
Fidanza light weight flywheel
Zzp stage 3 clutch kit
New throw out bearing, and pilot bushing
Zzp throw out bearing spacer
Zzp stage 1 axles
Zzp billet front trans mount
Zzp rear trans mount spacer
Zzp billet rotated rear trans mount
All new hydraulic clutch system
ion redline manual pedal assemblies
New shift cables
Short throw shift kit and short throw adapter
Zzp Billet shifter bushings
05 - 06 saturn 2.2 l61 manual engine harness to get rid of tcm and tcm wiring
Clean up and paint trans gloss silver
This is my starting point and current goals. Once this is done i will post the rest of my build plans
05_ionS/C is offline   Reply With Quote
Old 04-06-2022, 01:21 AM   #2
05_ionS/C
2005 ION-2 Sedan
Default Re: 05 Saturn ion 2.2 l61 build (the journey to 400hp)
Old 04-06-2022, 01:28 AM   #3
05_ionS/C
2005 ION-2 Sedan
Old 04-06-2022, 01:56 AM   #4
05_ionS/C
2005 ION-2 Sedan
Curent mods are
-Lighting and electronics-
6000K LED head light bulbs
Purple LED front turn signal bulbs
Purple LED reverse light bulbs
Purple LED license plate light buib
Purple LED interior map light bulbs
Purple LED dome light bulb
Purple LED trunk light bulb
Boss audio head unit with Bluetooth
-engine n engine bay-
3" cold air intake
Cabon fiber air filter heat shield
Billet LS1 oil cap
Purple fender bolt kit
-not yet instslled-
Long tube header with catless mid pipe
New 02 sensors
New mls header gasket
New ARP header studs
New chrome 2.5" inlet/outlet high flow resonator
New chrome 2.5" inlet/ dual 3" outlet muffler
New 2.5" 2 bolt exhaust flange
2 weld on 02 sensor bungs (1 for down stream 02 and 1 for wide band sensor)
Jet performance MAF sensor
Purple 1/4" wire loom
Purple LED strips 2 for under dash for front floor, 2 for under seats for rear floor, and 2 for inside trunk
New valve cover gasket
New spark plugs
-ordering on Friday-
Zzp 140mm adjustable stabilizer links
Zzp billet motor mount
Zzp rack spacers
Zzp camber adjustment bolts
Old 04-06-2022, 02:04 AM   #5
05_ionS/C
2005 ION-2 Sedan
The fiance loves the saturn as much as i do
Old 04-06-2022, 02:10 AM   #6
05_ionS/C
2005 ION-2 Sedan
Idk what it is about this car that's made me like it so much but cant wait to start actually building and missing this car. Have so many plans. Can't wait to get the suspension and 5 speed swap done so i can move onto building the engine and doing the engine bay.
Old 04-06-2022, 02:19 AM   #7
05_ionS/C
2005 ION-2 Sedan
Ill be ordering stuff every pay as im able to until i have everything i need for a full suspension build and brake upgrades. Next pay i will be ordering my good ridge stainless brake hoses, and front and rear cobalt ss 5 lug hubs and possibly the wheel adapters. I want to get all the smaller cheaper stuff out the way so i can start saving for the bigger stuff like the coil overs, brembo front brake kit, and tubular lower control arms. But i will update as i get the parts and i may start a YouTube channel to show the build as im building it, and show people how to install the mods, and what kind of stuff needs to be done to do the mods, so stay tuned cause there is alot to come.
Old 04-06-2022, 03:30 AM   #8
05_ionS/C
2005 ION-2 Sedan
Also one thing that i forgot was that ill be doing the suspension, and full 5 speed swap at the same time, and while im doing the 5 speed swap, since ill already be changing the engine harness to a manual engine harness to due away with the tcm and tcm wiring and id like to reloom the harness in purple, ill also br purchasing and installing megasquirt ms3x system, which will control my ignition, and fuel. The ms3x will be wired in parallel with my existing ecm, as to retain all the factory functions, and accessories, such as my stock gauges, A/C, drive by wire system, cruise control, etc. But ill have the tunability of a full stand alone system and have complete control over my engine. After this is done ill be starting my engine build.
Old 04-06-2022, 05:35 AM   #9
ultravioletnk
ultravioletnk will become famous soon enough
ultravioletnk's Avatar
2000 SC2
damn, i'm not much for the ions (they're gm delta cars with saturn's plastic body panels slapped on, but to their credit they did make a quad coupe version like the 3rd gen sc2s) but this is an interesting potential build! i'd love to see some pics of the suspension parts when they go on :3 and if you're able to get 400hp out of one of those ecotec things (don't get me started on the water pump being on the timing chain inside the crankcase) you should have a scary fast vehicle there!
rings-1996 sl2 ~215k mi
phoebe-1995 sl1 ~250k mi
janus-2000 sohc2 ~190k mi
tethys-1994 sw2 ~302k mi
rip mimas-wrecked 1996 sw1-trailer
pandora-1999 sc2
dione-1998 sw2
penny [iapetus]-1997 sw2
ultravioletnk is offline   Reply With Quote
Old 04-24-2022, 01:34 AM   #10
goaliemo
goaliemo will become famous soon enoughgoaliemo will become famous soon enough
2003 ION-1 Sedan
2006 ION Red Line
Save money on the tubular control arms and get fe5s from a 08-10 cobalt ss/t.c.
Should've went with a mid length header. But I dont know what your engine plans are. So the longtube may help your end goal.
F23 is a better trans than the f35. Plus more plentiful.
If I ever decide to drive my redline again, it'll get f23 swapped.
I've done the 5 lug/fe5 swap on a sedan before. It was pretty simple
I'm just a guy that enjoys my Ions.
Try Google, first. Then ask.
goaliemo is offline   Reply With Quote
Old 04-29-2022, 09:03 PM   #11
rjc862003
rjc862003 is a jewel in the roughrjc862003 is a jewel in the roughrjc862003 is a jewel in the roughrjc862003 is a jewel in the rough
I doubt it highly GM did race testing on the 2.2's the stock powdered rods disintegrate at >280hp
a newer (06 and up) might have better rods tho
https://www.motortrend.com/how-to/tu...ecotec-engine/
400hp is completely possible but you need forged rods/pistons
rjc862003 is offline   Reply With Quote
Old 05-01-2022, 12:46 AM   #12
goaliemo
2003 ION-1 Sedan
2006 ION Red Line
You are correct. 280 is pushing it. And that's using e85 and methanol.
Cheap to build the bottom end
Old 07-21-2022, 10:09 PM   #13
Trexer
Trexer is on a distinguished road
2007 ION-2 Sedan
2007 VUE 3.5L
Anxiously awaiting seeing some results of this project. I'd be happy to learn from your successes and steal them for my own, lol.
Trexer is offline   Reply With Quote
Old 02-05-2023, 01:42 PM   #14
Trexer
2007 ION-2 Sedan
2007 VUE 3.5L
Any progress?
Old 03-17-2023, 09:41 PM   #15
02 LW300
02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold
02 LW300's Avatar
2002 L-Series 3.0L Wagon
2002 L-Series 2.2L Sedan
Billy is very busy with many projects. Probably why he has not got back to this thread.
2002 LW 300 loaded, just rolled 100,000 miles, new timing belt and goodies
2002 L200/5 Loaded, 280k grandson’s car
2000 LS1, TMU love those bcm failures., grand daughter’s car
Old 05-24-2023, 07:29 PM   #16
SimbaUchihaa
SimbaUchihaa is on a distinguished road
So, how did this project end up? The I never thought about using the ms2x, I've heard of the haltech but there's no plug n play for kit like for other Cara. Hmmmmm.
SimbaUchihaa is offline   Reply With Quote
Old 05-28-2023, 07:08 PM   #17
Anduu
Anduu is on a distinguished road
Anduu's Avatar
2005 ION-2 Quad Coupe
It has been over a year...let it rest in peace.
Anduu is offline   Reply With Quote
Old 09-15-2023, 02:15 PM   #18
SimbaUchihaa
Not understanding the purpose of your post
Old 09-20-2023, 11:29 PM   #19
Anduu
Anduu's Avatar
It means there hasn't been any kind of update in over a year and the project is likely dead.
Also it was a total pipedream to begin with.
New to me '96 coupe and my journey cpy911 S-Series General 25 12-11-2017 01:14 PM
Impending Journey's End stoickiwi Astra General 6 08-12-2014 08:43 AM
My journey. Car back from shop DB42 S-Series General 5 01-31-2012 09:56 AM
Interesting journey with my SC2 dsdSC97 S-Series General 4 06-18-2003 09:25 PM
