I helped my friend replace his waterpump on his 93 SC2 yesterday, cause it finally died. We filled the system back up with water and coolant, and then let it run to check for leaks. It was working perfectly. We went for a drive, and noticed that the car started to heat up, and wouldn't cool back down. We took it home, and everything seemed ok, but when the car was cold, he took off the coolant resevior cap, and coolant came running out of it. He filled it back up to the lower level, and then went for a drive again. The same thing happened, only it took longer for the engine to heat up. Any idea why this is happening? The thermostat is opening up because both radiator hoses heat up and he has lots of heat in the car.
A few questions. How hot is the car getting when you guys are driving it around? The system is pressurized so it will spew coolant if you take the cap off too fast.
Did you check the all the hoses for a collapsed hose? Does the fan turn on when your temp needle reaches the 3/4 mark? When's the last time you changed the ECTS? |
![]() Join Date: May 2004
Location: spring hill tennessee (the motherland) sterling heights michigan native
1994 SL1
start the car and let it run with the radiator cap off until it gets hot. sound slike you have a ari bubble in the system
remember that cars are built by robots built by human hands and are prone to failure. |
![]() Join Date: Jun 2002
And DO NOT put the cap back on until the engine is COLD!
Did you also change out the thermostat?
85 GLH 367whp. http://www.saturnfans.com/forums/showthread.php?p=2261629#post2261629 00 Insight 72mpg |
#5 |
Saturn cooling systems are self purging...it's NOT an "air bubble" Either the water pump taint pumping, (it's new so unless the belt is slipping horribly..unlikely) the radiator is internally clogged or externally blocked airflow wise (put a piece of carboard or? to protect it while you were working around it?) or the thermostat IS sticking shut. My money is on the thermostat. NOTE: The heater WILL get hot water (produce heat) LONG before the thermostat opens...it's designed that way. It IS possible for the upper and lower radiator hoses to be warm and the thermostat to still be stuck fully or partially closed.
Old Saturns never die, people KILL them, so check your damn oil! "Unthinking respect for authority is the greatest enemy of truth." Albert Einstein |
I think it's on the original thermostat, and the temp will increase all the way to the red mark, until the fan comes on, then it just stabilizes really high and doesn't come back down until you shut the car off. The temp goes up quicker with faster car speed.
#7 |
Change it.
#8 | |
![]() Join Date: Dec 2003
#9 |
![]() ![]() ![]() ![]() Join Date: Apr 2000
2007 ION-2 Quad Coupe
1997 SC1
IIRC you can get an OEM stat & ECTS for about 20 bucks total.
#10 | |
#11 |
I'd also check the correctness of coolant-water mix-ratio.....
Maybe too much water in the coolant? Typical mix should be 50/50 (water/green) and some extreme weather may require 30/70 or 20/80.....depends. |
#12 |
![]() Join Date: Jul 2004
Wolfman is right! Saturns purge air very quickly through the Small lines at the top of the reservoir. You might consider that your friend got the thing hot at the time he discovered the leaking pump and it now has head or headgasket troubles. I'm assuming that before he got into the water pump trouble thing that it was acting normally.
Weird Cooling Fan problem | Dime333 | S-Series Tech | 6 | 08-05-2009 10:02 AM |
Cooling System Problem? | kyasarin | S-Series Tech | 7 | 07-26-2009 09:14 AM |
cooling system refill problem..... | plum_sc2 | S-Series General | 32 | 01-08-2005 01:09 PM |
Cooling System over pressure problem | flyingw80 | S-Series Tech | 22 | 10-23-2003 11:36 AM |
Cooling system problem | looneyluden | Miscellaneous Tech | 6 | 10-25-2000 07:41 PM |
