Old 02-25-2004, 05:46 PM   #1
ym42
ym42 is on a distinguished road
Default CCPS Canister Purge Solenoid
I HATE THIS THING!
I spent about 20 minutes under the car looking for it. I browsed thru the Forum, looked at the manual: everybody failed to mention it is behind the starter and you can not see it either from under or above the engine! Only if you take the starter off, you might see it.
Next 20 minutes I spent trying to get those hoses and wires off it. The hoses did not want to slide off like Wolfman said, it is very awkward there and one hose broke as I could not coordinate the forces. The other one did come off after another 10 minutes, but I felt my hands were about to do the same thing! 10mm socket that I had did not work, and I connected a new solenoid without attaching it just to check if that will cure the SES light problem.
It did, my SES light does not light any more. But now I need to get another 10mm socket, new vacuum hose, and probably spend another hour or so to finish what I had started.
I hate that thing!
ym42 is offline
Old 02-25-2004, 05:49 PM   #2
bennett9000
bennett9000 has a spectacular aura aboutbennett9000 has a spectacular aura about
bennett9000's Avatar
Default
Yikes. I feel your pain.
Stupid emissions
-Andy
01 SL1 (2011-2014) 99 SW2 (2002-2009) 95 SL2 (1997-2002)
00 ROUSH Cougar V6 03 SVT Focus #2370 08 Mustang Bullitt #5389 2013 Fiat 500 Abarth
bennett9000 is offline
Old 02-25-2004, 05:54 PM   #3
TedL
TedL is on a distinguished road
Default
Remember: LABATYD
Focus on the $$ you're saving.
TedL is offline
Old 02-25-2004, 08:28 PM   #4
wolfman
wolfman's Avatar
Default
Just an FYI. Even some techs DO NOT remove the old CCPS. They (I) just tie wrap a new one up under the manifold securely and hook it up. This will not cause any issues and it will work just as well with alot less hassle.
wolfman is offline
Old 02-26-2004, 01:54 AM   #5
94sc293sl1
94sc293sl1 is on a distinguished road
94sc293sl1's Avatar
1994 SC2
Default
Funny you should mention that part. My neighbor helped me change it. Actually, he did the work since he can do a job like that just by feel. If I had done it, who knows what I would have screwed up.
Craig
Saturn owner no longer as of 12/21/05, sold my SC2.
www.insidetrackmagazine.com
94sc293sl1 is offline
Old 02-27-2004, 03:11 PM   #6
Pete93SL1M
Pete93SL1M is on a distinguished road
Pete93SL1M's Avatar
Default
I hate that thing, cost me $$ to have a mechanic take the intake manifold off to install a new one after I broke vacuum lines and stripped the bolt. Stupid SES light! argh! Now I feel much better.
..aka GMinTheDriveway
Former Saturn Sales Consultant
Give me choices in powertrain, great handling and decent MPG and I will buy a Saturn again.
Pete93SL1M is offline
Old 02-27-2004, 08:21 PM   #7
ym42
Default
Well, rubber lines are not hard to replace, and need to be replaced anyway, and talking about the bolt, as Wolfman said, many mechanics jsut attach it somewhere there without taking the old CCPS off the engine... You could have saved all those money...
ym42 is offline
Old 02-28-2004, 12:06 PM   #8
Luke
Luke's Avatar
Default
Gee guys, I was able to replace mine, simply from underneath. As a side note to Wolf's suggestion; I did think that the next time, I would just place the unit on the fire wall and extend the vacuum hoses.
Luke is offline
Old 03-06-2004, 11:44 PM   #9
ym42
Default
OK, here is the update. I drove my car into the garage, switch on all the lights and started thinking. I took the air cleaner housing off, and I could see the CCPS clearly from the top, right under the intake manifold. I was able to unscrew the 10mm bolt quite easily with the ordinary 10mm tool, and take the solenoid off the car. Replacing the vacuum hose was not hard at all either. So I would personally recommend to do it from ABOVE the car, not under. It took me about 40 minutes to do this, may be a little more.
ym42 is offline
canister purge solenoid - where can I buy!! lee L-Series Tech 3 03-25-2008 08:11 PM
? for anyone who has replaced ur ccps (carbon canister purge solenoid) xupthree60 S-Series General 3 04-08-2006 02:45 PM
CCPS (Carbon Canister Purge Solenoid) location? xupthree60 S-Series General 2 03-25-2006 02:05 PM
canister purge solenoid jaylie S-Series Tech 1 09-25-2005 10:30 PM
Location of canister purge solenoid and vent solenoid? jslw300 L-Series Tech 2 05-05-2005 07:36 PM
