Old 04-23-2013, 03:18 PM   #1
hunt4steve
hunt4steve is just really nicehunt4steve is just really nicehunt4steve is just really nicehunt4steve is just really nicehunt4steve is just really nice
hunt4steve's Avatar
1993 SC1
Wrench Hunt4Steve's 1993 Carrier Bearing Replacement for Intermediat Shaft
I decided to pull apart the intermediate shaft and replace the bearing inside the carrier that is bolted to the engine block.
Whole lotta rust....
Pealing the old seal out
Normally there is a fair amount of protective grease on the inside of the slinger, which is only there to protect the bearing. However, in this case you can see how a good portion of the grease is missing.
Pressing the shaft out of the carrier
Don't forget to remove the snap-ring before trying to press out this bearing.
hunt4steve is offline   Reply With Quote
Old 04-23-2013, 03:21 PM   #2
hunt4steve
hunt4steve's Avatar
1993 SC1
Pressing the carrier bearing out of the Intermediate Shaft Carrier
New Bearing on left from Napa, and the old bearing on right
Carrier. Note there is a shelf that will stop the bearing from being pressed through the carrier.
Pressing in a new bearing
New bearing pressed in, with the snap ring in place, and the old bearing to the right
Old 04-23-2013, 03:25 PM   #3
hunt4steve
hunt4steve's Avatar
1993 SC1
The Intermediate Shaft was fairly rusted. I took a wire brush to it to removed the rust and then lay down a few coats of paint
Cleaned of rust
Painted up
Pressing the Carrier Bearing along with the Carrier, onto the Intermediate Shaft.
Pressed in place
Old 04-23-2013, 03:26 PM   #4
hunt4steve
hunt4steve's Avatar
1993 SC1
Installing a new seal
Old 04-23-2013, 04:21 PM   #5
colonelhogan44
colonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of light
colonelhogan44's Avatar
Default Re: Hunt4Steve's 1993 Carrier Bearing Replacement for Intermediat Shaft
Excellent! You should put these in the How-To Library.
MechE - I make things!
EGR ADAPTERS AVAILABLE! $30 "reverse" $40 standard
1998 SL2 (gone, never forgotten)
2005 Volvo S40 T5 AWD
1987 Mercedes 300D
1993 Tracker 4x4
1996 Tracker 4x4
Old 05-04-2013, 11:23 AM   #6
motrhed79
motrhed79 is on a distinguished road
motrhed79's Avatar
Excellent write up, I'm glad to know the bearings in those are servicable now that those intermediate shafts are unavailable from GM.
Do you have a part number for the seal?
Ford Senior Master Technician
Current fleet:
~02 SC2 Rebuild thread http://www.saturnfans.com/forums/showthread.php?t=181982
~00 F150
Saturns from my past ~95 SL1, ~97 SL2
motrhed79 is offline   Reply With Quote
Old 05-04-2013, 11:25 AM   #7
There are several different designs of that shaft bearing assembly so knowing the year is important to getting all the correct parts to do the rebuild.
Old 05-04-2013, 02:33 PM   #8
hunt4steve
hunt4steve's Avatar
1993 SC1
For my 1993 saturn the required bearing is a 6206, as indicated by the box in the picture.
Old 05-04-2013, 02:36 PM   #9
hunt4steve
hunt4steve's Avatar
1993 SC1
As OldNuc has stated, each year may be different. I believe my seal was a 4614N. Autozone will have the seal numbers for your year car.
Old 03-19-2022, 04:39 PM   #10
bumpdraft
bumpdraft's Avatar
1998 SW2
A working link, with pictures:
https://sites.google.com/site/hunt4s...ng-Replacement
carrier bearing, drive shaft, intermediate shaft, rebuild
Hunt4Steve's 1993 MP2 5-spd Transmission rebuild hunt4steve S-Series Tech 35 03-19-2022 04:42 PM
balance shaft bearing carrier gillism L-Series Tech 1 01-23-2011 03:39 PM
Rdm,carrier bearing replacement update bob3434dog Vue General 7 11-13-2008 08:32 PM
HELP! Propeller Shaft carrier bearing trials183 Vue Tech 1 09-30-2008 08:53 PM
Prop Shaft Carrier Bearing Replacement? wfransee Vue Tech 3 08-14-2008 01:11 PM
