Old 03-16-2021, 09:01 PM   #1
01SC94SL
01SC94SL is on a distinguished road
01SC94SL's Avatar
2001 SC1
1994 SL1
Default TBI vacuum hoses gasket
I have a 94 SL1 SOHC. I'm having idle issues. Just rebuilt the engine with all new pistons, rings, bearings, gaskets, timing chain kit, wires, plugs, motor mounts, clutch kit...everything. Head was professionally rebuilt, block was also checked cleaned and cylinders bored out. Crankshaft was sent out and checked. Big vibration at idle and gets less with more gas.
I replaced all the vacuum lines with new firm rubber hoses with no change. I took apart the throttle body. The gasket on the back where the evap, egr sol., and map go into is toast. I'm hoping this is my problem but I can't find the correct new one. I found a throttle body rebuild kit a few places but the review on it says that the gasket for that part that comes with it is incorrect and doest work. Does anyone know the gm part number or somewhere I can get one? Finding anything on first Gen throttle body is hard
Any suggestions or questions are appreciated
94 SL1
01 SC1
08 Aura
01SC94SL is offline   Reply With Quote
Old 03-16-2021, 11:07 PM   #2
Default Re: TBI vacuum hoses gasket
Tried rockauto.com? The rebuild kit for throttle body injectors comes with gaskets and fuel pressure diaphragm to regulate pressures. Most members here use the kit with success. The injector may be worn out too and leaking. The easiest way to tell if its leaking is turning on ignition, engine off so the pcm cycles the fuel pump then shuts off if the engine isn't started. Look down the throttle bore to check for fuel flowing out the injector. With ignition on, engine off, the injector should be shut off. Any fuel seeping out indicates a pintle valve leak and should be replaced.
Old 03-16-2021, 11:54 PM   #3
Pretty sure all you need to do to make the S-Series TB work on the 7.4L BBC is swap the injector. Odd that what sounds like a standard O-ring doesn't swap.
Wondering about vacuum leaks / hoses atroxguy S-Series General 5 08-27-2019 02:36 AM
I'm looking for new vacuum hoses Frankd1 S-Series Tech 5 02-06-2009 09:03 PM
vacuum hoses on throttle body sc2dohc94 S-Series Tech 5 03-16-2008 02:18 PM
Where are all the vacuum hoses? jamman S-Series General 1 04-22-2006 11:07 PM
Where to buy vacuum hoses? ProDarwin Miscellaneous Tech 8 12-24-2003 12:52 PM
