Old 09-13-2015, 09:04 PM   #1
jhoma
jhoma is on a distinguished road
2008 VUE 2.4L
Default 2008 Vue only blows cold air
We have a 2008 Vue XE with about 44,000 miles on it. The automatic climate control system has worked fine up until the time I turned the right-hand control to the "defrost" position to clear the windshield on a foggy, rainy day. The outside temperature at the time was about 55F. We noticed that the temperature in the vehicle started to get quite cold, so we turned up the temperature control. The fan speed increased, but the interior temperature just got colder. Now, the only location that air will come out is from the dash vents. Turning up the temperature only increases the fan speed, but the temperature stays cold (or gets even colder). Turning the right hand control off "auto" to the other air control modes has no effect; the air only comes out of the dash vents. Again, up until this event, the system worked just fine. Has anyone seen this problem and fixed it?
jhoma is offline   Reply With Quote
Old 09-14-2015, 09:03 AM   #2
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
Default Re: 2008 Vue only blows cold air
thermostat??? is engine coolant getting warm?
Old 09-14-2015, 08:36 PM   #3
jhoma
2008 VUE 2.4L
I believe that the thermostat is working properly. What is the best way to tell?
Old 09-15-2015, 10:04 AM   #4
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
temperature gauge. if it goes up to where it should its working
Old 09-15-2015, 09:08 PM   #5
jhoma
2008 VUE 2.4L
Believe it or not, I pressed the "AC" and "recirc" buttons simultaneously and the system started to work again. Has anyone seen this one before?
Old 09-15-2015, 09:29 PM   #6
AC+recirc = (hidden) reset of the climate control head?
Old 09-16-2015, 09:21 PM   #7
jhoma
2008 VUE 2.4L
I wonder if it is. The LED on the recirc button flashed several times after I pressed it and the AC buttons simultaneously. I thought I read at one time that pressing these two buttons would update the temperature display on the instrument panel; I'm not sure if any other functions are performed.
Tags
2008 vue, vue climate control
2008 astra cold air piggymoose Astra General 10 07-11-2014 09:06 PM
99 SW2 Overheat, blows cold inside, ??? ww2steel S-Series Tech 7 05-29-2012 01:52 PM
Park Light Fuse blows and blows. heavyd10000 S-Series Tech 6 09-14-2009 03:05 PM
A/C blower on-bump-off-slow-fast-off- ..a/c blows cold roktsyntst S-Series General 5 06-27-2009 10:22 AM
AC Only Blows cold when driving. cptcrnch S-Series Tech 3 09-14-2008 03:05 PM
