Old 05-10-2015, 01:29 AM   #1
bachands
bachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to behold
Default TAAT shift solenoid compatibility
My valve body cover seems to be leaking slowly so I will be replacing the gasket soon. Just in case, I purchased a couple of good solenoids. The part # on them is 21003289. Reading one of the TSBs, I noticed that P/N 21003289 was discontinued mid-1999 and replaced with P/N 21003344. Unfortunately, my '99 SL2 is AFTER the VIN break.
Question:
Will I have problems if I use P/N 21003289 solenoids to replace any bad P/N 21003344 solenoids that might currently be in there? Is it absolutely necessary to use P/N 21003344 solenoids with this trans?
bachands is offline   Reply With Quote
Old 05-10-2015, 08:34 AM   #2
Default Re: TAAT shift solenoid compatibility
They will work fine if good.
Old 05-10-2015, 08:37 AM   #3
Chazberry
Chazberry's Avatar
1995 SW2
I'll say no. I just put a 21003344 in my '95 and it works fine, so I'd say they are compatible.
Old 05-10-2015, 09:52 AM   #4
bachands
Okay, thank you both.
The resistance measured 4.5 ohms for each. Is there another way I can test them? Can I supply 12 volts to the leads to make sure they actuate or is that the wrong voltage?
Old 05-10-2015, 09:57 AM   #5
Chazberry
Chazberry's Avatar
1995 SW2
Couldn't hurt to do that.
WTB -- TAAT Trans solenoid(s) bachands Classifieds 2 05-10-2015 12:22 AM
TAAT solenoid Q marko16 S-Series Tech 3 05-02-2015 08:53 PM
1999 Saturn SL1 TAAT Soleniod Compatibility jcumens S-Series Tech 2 03-01-2014 02:32 PM
TAAT Solenoid Lock up flaniganjasonl S-Series Tech 7 06-25-2013 08:46 PM
TAAT Solenoid Help BRIAN41920 S-Series Tech 1 09-22-2010 02:11 AM
