Old 01-11-2014, 02:45 PM   #1
Upstate Saturn
Upstate Saturn is just really niceUpstate Saturn is just really niceUpstate Saturn is just really niceUpstate Saturn is just really niceUpstate Saturn is just really nice
Upstate Saturn's Avatar
2001 SL2
Default 2001 SL2 Clicking noise turning wheel when stopped
When I turn my wheels when stopped, I hear a clicking noise coming from the front end. It's worse if I crank the wheel all the way over. When driving it seems fine, I don't hear any noises when turning, or feel anything out of whack in the front end. What do you suppose is wrong?
The car is a 2001 SL2 with 200k miles on it. Thanks for any advice you can give.
Upstate Saturn is offline   Reply With Quote
Old 01-11-2014, 02:54 PM   #2
caveeagle
caveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of light
caveeagle's Avatar
Default Re: 2001 SL2 Clicking noise turning wheel when stopped
Upper strut mounts are dry or worn out?
Mark
'05 Vue, '02SL1, '01SC2a, '01SC2b, '99SL1 :::::> '04 SVT Cobra, '67 Mustang Vert.
caveeagle is offline   Reply With Quote
Old 01-12-2014, 08:36 AM   #3
wi111y
wi111y is on a distinguished road
1995 SL
1995 SW2
You sure it's from the front end? Mine made a clicking noise in the wheel when my clock spring got broken.
'95 SL 5 Speed 220k - DD
'95 SW2 5 Speed 230k - Gone!
'95 Camaro Z28 - Project
'00 Tahoe Z71 - Truck stuff
wi111y is offline   Reply With Quote
Old 01-12-2014, 02:10 PM   #4
Upstate Saturn
2001 SL2
Yes, I'm sure it's from the front end, and it only happens when I am actually turning the wheel.
What is a clock spring? When did they start putting springs in digital clocks?
Old 01-12-2014, 02:15 PM   #5
caveeagle
caveeagle's Avatar
What is a clock spring? In a digital clock?
The clock spring (stupid name) is inside your steering wheel. Its what allows all your steering wheel electronics (airbag, cruise, horn) to maintain an electrical connection when you turn the wheel in circles. Wires would just bind, wear out and break.
Like I said earlier, I suspect your noise is comming from you upper strut mounts. Whenver you turn your front wheels, of hit a bump or brake hard, all the front geometry changes. The upper strut pivot allows the strut to move around to adapt to this. Age, cold weather, lack of lubrication can cause these to make noise.
You might try to get some lubrication up in there to see if it quiets down.
Mark
Stearing wheel made clicking noise while turning. Daytripp S-Series Tech 3 08-10-2011 06:19 AM
clicking noise when turning, bad cv joint? munky000527 Ion Tech 11 02-23-2011 08:16 PM
Clicking noise when turning left lost_wreckage S-Series General 8 10-11-2010 01:08 AM
Noise when turning the wheel when stopped .kevin. S-Series Tech 1 07-27-2010 12:22 AM
Clicking noise when turning the wheel while backing up j2s2why Outlook General 3 09-05-2007 12:40 AM
