Old 09-29-2011, 09:41 PM   #1
kink2227
kink2227 is on a distinguished road
Default fuel pump removal from tank
I am replacing a fuel pump on a saturn lw200 and having troble removing the fuel pump from the tank. I removed the ring on the top of the module that holds it to the tank. then i lifted and rotated the the pump and i almost got it all the way out but the sending unit arm is hanging up on the tank hole. i dont want to break this so i am wondering how this is done. Do i have to remove the sending unit inside of the tank or will it come out all in one piece. i searched but didnt find much on this. i see something that says set it in the 1oclock position and tilt 45degrees or something like that. i am confused so if anyone could help it would be great. Thanks
kink2227 is offline   Reply With Quote
Old 09-30-2011, 08:51 PM   #2
Paradoxmaker
Paradoxmaker has a spectacular aura aboutParadoxmaker has a spectacular aura about
2002 L-Series 3.0L Wagon
1999 SL1
Default Re: fuel pump removal from tank
It will come out but it's a very tight fit.
Pull the pump up as far as it will go, and tilt it until the side opposite the sending unit clears the tank lip. Once cleared the sending unit side comes out easily.
Just replaced my fuel pump a couple of weeks ago.
Paradoxmaker is offline   Reply With Quote
Old 01-29-2012, 11:32 PM   #3
tomtyo
tomtyo is on a distinguished road
Thanks for the info. I couldn't get my 2002 L200 pump out until I read this!
tomtyo is offline   Reply With Quote
Some Pictures of Fuel Tank Removal.... jigawatt77 S-Series Tech 8 07-23-2012 12:58 AM
Remove fuel pump from gas tank eimajenthat S-Series Tech 16 11-22-2010 08:50 PM
'93 SW2 Fuel Tank removal ?? fredsfix S-Series Tech 10 03-28-2008 10:50 AM
Fuel Tank removal glp103 S-Series General 3 10-17-2005 09:44 PM
Lowering fuel tank & replacing pump Question ( 95SL2 ) Luke S-Series Tech 9 05-15-2003 07:50 PM
