Old 01-26-2010, 11:35 PM   #1
Rob Zane
Rob Zane is on a distinguished road
2001 SL2
Default 2001 SL2 TAAT Shift Points
I'm new to the Saturn family and have read that the TAAT locks up the Torque Converter after the 2nd gear is engaged. Can anyone confirm that the following is a "normal" shift sequence for this car?
During normal, warm engine conditions, smooth acceleration from stop to 50 mph,
1st gear, engine idle at 800 rpm, as I accelerate rpm rise to 2500 rpm(15 mph)
2nd gear engages and rpm drop by 200 rpm to 2300 rpm
Under smooth acceleration, rpm rise to 2500 rpm and suddenly drop to 2200 rpm. Is this the torque convertor lock-up?
Under continued smooth acceleration, rpm rise again to 2800 rpm (31 mph)
3rd gear engages, rpm drop to 1900 rpm
Under continued smooth acceleration, rpm rise to 2600-2700 rpm (44 mph)
4th gear engages, rpm rise to about 2000 rpm (50 mph)
I don't have any of the reverse "slam" or 2nd gear slippage issues reported unless the post 2nd gear drop in rpm is slip and not torque converter lockup.
Rob Zane is offline   Reply With Quote
Old 01-27-2010, 12:34 AM   #2
rc1488
Default Re: 2001 SL2 TAAT Shift Points
Under smooth acceleration, rpm rise to 2500 rpm and suddenly drop to 2200 rpm. Is this the torque convertor lock-up? yes
Your missing some rpm drops Under smooth acceleration the blend in and happen almost immediately after the shift.
Before each shift after second gear, the torque converter unlocks. It then relocks once in the next gear. Under semi hard load you'll hear each shift then each lock up point. This is why some people are not used to the s-series tranny and feel its acting weird.
If you really slam the accelerator, the converter will unlock while staying in gear instead of downshifting. It the load is to great, it will then downshift.
Old 01-27-2010, 12:35 AM   #3
Special Forces
Special Forces has a spectacular aura aboutSpecial Forces has a spectacular aura aboutSpecial Forces has a spectacular aura about
Special Forces's Avatar
2006 ION Red Line
Looks normal to me.
/// Need rebuilt valve bodies? PM Me. \\\
//// Why bother with ebay when I'm right here? \\\\\
Valve bodies built to order
Please PM me about valve bodies, do not post a visitor message.
Special Forces is offline   Reply With Quote
Old 01-27-2010, 05:43 AM   #4
Rob Zane
2001 SL2
Thank you for the confirmation of normal shift sequences and the enhanced explanation of additional pre-shift unlocking of the torque converter. I will try harder accelerations to see if I can feel this happening.
Thanks again
Old 01-28-2010, 10:38 PM   #5
danger09
danger09 is on a distinguished road
So there is no question that little drop in rpms is normal on automatics before the third gear shift? does this feel kinda like the transmission has a hesitation before it shifts?
danger09 is offline   Reply With Quote
Old 01-28-2010, 10:44 PM   #6
rc1488
Totally normal for s-series cars.
Old 01-28-2010, 10:57 PM   #7
danger09
thank you. All along i thought there was something wrong. So i changed the transmission out and it did the same thing All that work for nothin.
Old 01-28-2010, 11:33 PM   #8
rc1488
oh noooo!!
Yes most trannies don't do this. They lock up in 3rd or only 4th. But the s-series is different
Old 01-28-2010, 11:37 PM   #9
danger09
lol i wish had known that before hand. (never had an s-series auto before) It definately feels a lil strange. I thought it was slippin for sure
Old 01-28-2010, 11:59 PM   #10
Rob Zane
2001 SL2
I also was thinking for sure my TAAT was slipping during the 3rd gear shift. Glad to hear its "normal" for the S-series. Sorry about all the work you did swapping out the transmission. A big thanks again to all for the helpful insight and information.
Tags
shift sequence, taat
Shift points kcps1717 S-Series General 25 01-31-2008 11:55 AM
03 shift points bergfire Vue Tech 2 01-08-2008 01:36 AM
Shift points for MPG lovemysan S-Series General 6 05-22-2006 09:22 AM
Best Shift Points? HiWire S-Series Mods 44 11-01-2004 12:20 AM
D1 shift points 3der Vue General 3 01-22-2003 05:45 PM
