Old 03-23-2009, 01:54 AM   #1
madgor
madgor is on a distinguished road
Default P0700 P0442 SES Codes
Hey guys I'm back with a new problem. Before I posted about an unknown error code that was discovered to be P0843 and P0841. It was taken into the dealer to have the VTI transfer case cover, torque converter, and fluid pump replaced. Now I'm getting the above P0700 and P0442 error codes. Any idea on the cause and cost of repair.
By the way its a 2003 AWD.
madgor is offline   Reply With Quote
Old 03-23-2009, 06:05 AM   #2
Default Re: P0700 P0442 SES Codes
DTC P0442 Evaporative Emission (EVAP) System Small Leak Detected
DTC P0700 Transmission Control System Malfunction
The first eror code is mostly the gas cap code, loose gas cap needing cleaning and tightening. The second error code may be the result of the transmission service. Either reset these two codes and see if they come back (the gas cap leak should go away) or return to the dealer to have the transmssion looked at again.
saturn L300 trouble codes P0700 & P0727 kssbss L-Series Tech 14 07-10-2017 01:23 PM
New View - P2176 and P0700 codes Raysp30 Vue Tech 5 09-18-2011 04:52 PM
Codes P0700, P1758 cutiep Vue Tech 3 05-05-2009 01:58 AM
2003 L300 error codes P0700 & P0727 kssbss L-Series General 1 12-28-2008 08:29 PM
Codes p1779, p1791, and p0700 found LBL300 L-Series Tech 7 03-12-2008 11:27 PM
