Old 10-15-2007, 05:26 PM   #1
Alex_SC2
Alex_SC2 is on a distinguished road
Alex_SC2's Avatar
Default RKE Module Location
Would anyone here care to enlighten me as to the location of the RKE module in my 2002 SC2?
I looked behind the passenger side C-pillar seat trim, which is where it was on my '99 but on the '02 there is nothing there.
Human salvation lies in the hands of the creatively maladjusted.
2002 SC2 - 80,000km so far...
1989 Suzuki Katana 750 - Cheap thrills!
Alex_SC2 is offline   Reply With Quote
Old 10-15-2007, 06:09 PM   #2
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Default Re: RKE Module Location
Its integrated into the BCM.
Originally Posted by Low Saturn View Post
BCM Functions
The Body Control Module (BCM) performs multiple body control functions. The BCM can control devices directly connected to its outputs based on input information. The BCM evaluates this information and controls certain body control systems by commanding outputs on or off. The BCM control inputs can be:
Sensors and switches that are directly connected to the BCM
Class 2 serial data received from other control modules connected to the class 2 serial data link.
The BCM is also capable of controlling other vehicle systems that are not directly wired to the BCM. The BCM does this by sending specific messages on the class 2 serial data link. The control module capable of performing the required function will respond to the BCM message.
The BCM controls these functions:
--Audible warnings, refer to Audible Warnings Description and Operation in Instrument Panel, Gages and Console
--Automatic door locks, refer to Power Door Locks Description and Operation in Doors
--Automatic headlamp control, refer to Exterior Lighting Systems Description and Operation in Lighting Systems
--Interior lighting, refer to Interior Lighting Systems Description and Operation in Lighting Systems
--Keyless entry (AUO option), refer to Keyless Entry System Description and Operation in Keyless Entry.
--Passlock theft deterrent, refer to Vehicle Theft Deterrent (VTD) Description and Operation in Theft Deterrent.
--Retained Accessory Power (RAP), refer to Retained Accessory Power (RAP) Description and Operation in Retained Accessory Power
Serial Data Power Mode
On vehicles that have several control modules connected by serial data circuits, one module is the power mode master (PMM). On this vehicle the PMM is the Body Control Module (BCM). The BCM receives 2 signals/circuits from the ignition switch. These are the Ignition 1 and Ignition 3 signals/circuits.
Fail-safe Operation
Since the operation of the vehicle systems depends on the power mode, there is a fail-safe plan in place should the BCM fail to send a power mode message. The fail-safe plan covers modules with discrete ignition signal inputs as well as those modules using exclusively serial data control of power mode.
Serial Data Messages
The modules that depend exclusively on serial data messages for power modes stay in the state dictated by the last valid BCM message until they receive the engine status from the PCM. If the BCM fails, the modules monitor the serial data circuit for the engine run flag serial data. If the engine run flag serial data is true, indicating that the engine is running, the modules fail-safe to "Run". In this state the modules and their subsystems can support all operator requirements. If the engine run flag serial data is false, indicating that the engine is not running, the modules fail-safe to "OFF-AWAKE". In this state the modules are constantly checking for a change status message on the serial data circuits and can respond to both local inputs and serial data inputs from other modules on the vehicle.
Discrete Ignition Signals
Those modules that have discrete ignition signal inputs also remain in the state dictated by the last valid BCM message received on the serial data circuits. They then check the state of their discrete ignition input to determine the current valid state. If the discrete ignition input is active, B+, the modules will fail-safe to the "RUN" power mode. If the discrete ignition input is not active, open or 0 voltage, the modules will fail-safe to "OFF-AWAKE". In this state the modules are constantly checking for a change status message on the serial data circuits and can respond to both local inputs and serial data inputs from other modules on the vehicle.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
Old 10-15-2007, 09:37 PM   #3
Alex_SC2
Alex_SC2's Avatar
I was actually kind of hoping for that... You don't happen to have a wiring color diagram for the BCM do you? I plan to make some modifications to the automatic lighting system.
TIA
Old 10-15-2007, 10:00 PM   #4
Low Saturn
Low Saturn's Avatar
2007 AURA XR
TIA
Here ya go.
http://www.differentracing.com/mike/...ns/2002bcm.htm
Mike
-1991 Turbo SL2.
Old 10-15-2007, 10:08 PM   #5
Alex_SC2
Alex_SC2's Avatar
Thanks Mike!
I'm in need of a RKE Module diagram haakw S-Series Tech 3 06-02-2018 09:35 PM
1996 sl2 RKE module danboy S-Series Tech 2 01-12-2009 12:01 PM
97 SL1 Where is the RKE module? LTond56 S-Series Tech 3 09-28-2008 12:58 PM
1996 sl2 location of the RKE module red92xblue S-Series Tech 2 06-10-2008 03:08 AM
rke module location 94sc295sl2 S-Series General 4 04-08-2006 01:51 PM
