Old 07-26-2022, 10:23 PM   #1
ronbo97
ronbo97 is a jewel in the roughronbo97 is a jewel in the roughronbo97 is a jewel in the rough
Default 2002 Saturn SL-2 Air Conditioning Not Working
Hi Everyone -
The a/c on my 90K mile 2002 Saturn SL-2 just stopped working. The clutch on the compressor will not engage.
I've been reading the threads in the forums here, as well as watching richpin06a's videos on YouTube. I followed Rich's 10-step diagnostic, which is explained in a two part video of his. Most of the results are what is expected, with the following exceptions:
--When I paper-clip the pressure switch connector, the clutch does not turn. However, when I measure resistance (ohms) on the switch itself, touching each pin with a lead from the multi-meter, I do get a reading of 0, which means that the pressure is within spec. So that tells me it's charged. I have not messed with the R134a refrigerant.
--When I remove the a/c relay (gray cube in the fuse box) and check the four connection sockets, the compressor socket (lower left) resistance is supposed to be 00.0. But I get a reading of 42.3. When I check the 'live when car is running (#85) socket, lower right, I get a reading of 12V whether the car is running or not. I'm supposed to get a reading of 12V only when the car is running, according to the video.
As I mentioned earlier, the results of all the other tests are normal.
Can someone interpret this data for me ? Is the compressor toast ?
Thanks,
Ron
ronbo97 is offline   Reply With Quote
Old 07-26-2022, 10:59 PM   #2
ronbo97
Default Re: 2002 Saturn SL-2 Air Conditioning Not Working
OK. Here's an update: richpin06a is probably working with an older Saturn, as his fuse box looks different. I tested the sockets under the larger relay, which I believe is the cooling fan, thinking it was the a/c relay. The a/c relay is actually the smaller relay next to it.
So should I repeat the four-socket tests (trigger ground [upper left], live juice [upper right], compressor [lower left], live juice when running [lower right]) in the same manner, but this time using the sockets under the a/c relay ?
Thanks,
Ron
Old 07-26-2022, 11:19 PM   #3
Check for 12V at socket for pin #30, that should have power at all times. Then, jumper #30 to #87, that will bypass the relay and should energize the clutch coil.
Old 07-26-2022, 11:39 PM   #4
ronbo97
So is #30 upper right and #87, lower left ? If the clutch coil is energized, would it spin the clutch ? If it doesn't, what does that mean ?
Thanks,
Ron
Old 07-27-2022, 10:46 AM   #5
ronbo97, to prevent damaging your multimeter when measuring resistance circuits, I would recommend resistance measurements only on these parts,; relay coils compressor clutch and fuses. Relay coils removed, compressor clutch disconnected and fuses removed to measure them individually from their circuits to prevent incorrect feedback.
Ac pressure sensors are virtually fault free with only one exception from a recent Ion member proving his three pin ac sensor failed as soon as it was replaced. A repair shop actually informed him of this, unusual amongst dishonest repair shops. I've never read of anyone in these forums measuring two or three pin ac pressure sensors as this adds to confusion for diyers attempting ac repairs. All you needed to do was to disconnect the sensor connector and insert a paper clip into the connector. This bypasses the sensor altogether and should allow power to the compressor clutch. HINT; the cooling fan should turn on immediately when ac is turned on. If you see and hear the radiator cooling fan run and the engine isn't overheating, there should be power to the compressor clutch.
Measure for 12v on the compressor clutch connector. If you have 12v on the connector then the clutch coil thermal fuse is blown. If you do not have 12v on the clutch coil connector, did you check for a blown ac fuse?
4-pin 87a relays can be mistakenly inserted incorrectly. 5-pin 87a relays cannot be inserted incorrectly. Examine each relay;
there should be labeling either on one side of relay covers or underneath with pinout info. Fuse covers should have a diagram showing fuse and relay information.
Old 07-27-2022, 11:22 AM   #6
ronbo97
fdryer - Yes, I paper-clipped the sensor connector. When I turned on the fan and pressed the a/c button, clutch did not engage.
When you say 'compressor clutch connector', are you referring to the light blue connector at the compressor ? I assume so, but just want to verify. If so, I did test that and, yes, I'm getting 12V there.
Where is the clutch coil thermal fuse located ? I looked at the diagram on the fuse box cover and could not find that. I do see something called A/C diode. Is that it ?
I looked at the 10A a/c fuse and it looked good.
Ron
Old 07-27-2022, 12:31 PM   #7
ronbo97
Bill - I tried the test you mentioned. I have no voltage at pin #30, which is the lower left, according to the relay.
Ron
Old 07-27-2022, 01:33 PM   #8
Try at 87. I just checked, my gen1 is wired with the 87s "always hot", not the 30s.
Old 07-27-2022, 01:42 PM   #9
Yes, the single wire connecting to the compressor is 12v when ac is turned on (whether or not bypassing the ac pressure switch). 12v on the compressor connector means the ac relay energized and closed contacts 30 and 87, sending 12v power to the compressor. If toy didn't see 12v on relay socket terminal 30, check for 12v on 87. As mentioned previously, you should see and hear the radiator cooling fan run. This verifies the pcm is commanding power to the compressor and cooling fan. Ac generates heat; the condenser in front of the radiator gets warm or hot and air flows from condenser coil thru radiator so the cooling fan is turned on immediately to ensure the cooling system doesn't overheat in hot, humid, stop and go traffic with ac running.
If you heard the cooling fan turn on and have 12v on the single wire to the compressor (coil ground connects to compressor frame, grounded to engine block, engine block grounded to chassis stud near battery, chassis stud connected to battery negative), your compressor clutch is blown. To verify whether the clutch coil is blown, wire 12v directly from battery positive to compressor. Touch the compressor terminal with 12v momentarily or longer. You should see and hear the clutch engage with a loud metallic click. No electrical arc on the terminal, no clutch engagement, no metallic click from clutch plate slapping onto the idler pulley on the compressor means the coil is blown.
The thermal fuse is built into the clutch coil and cannot be replaced if its epoxied, sealed as a coil unit. Some have accessible thermal fuses but you have to disassemble the clutch from its center nut, remove clutch with a puller or sometimes it falls out then remove screws holding the clutch coil onto the hub and pull the coil off to examine it for thermal fuse replacement. Difficult to do on the car with ac hoses connected. When power is applied to the coil, you can see and hear the clutch plate slap onto the pulley with a loud metallic click and see the small gap between clutch plate and pulley disappear. The gap is around 0.015", easily seen when ac isn't running.
If your clutch coil is blown, you decide on whether or not to try removing and replacing the clutch coil or decide if you want to replace the entire compressor. Prices between a replacement clutch coil or compressor with clutch varies and you'll you need all the refrigeration equipment, replacement drier, seals, pag oil, and electric vacuum pump to replace a compressor. You'll need to know how to use refrigeration gauges, how to use the manifold valves at the appropriate time and how to refill pag oil removed from the original compressor. Work is not for the faint hearted but can be done by anyone willing to spend time, effort and learn new skills. All of this already covered several times in past threads. AutoZone is one place with loaner tools to save on investing in refrigeration equipment but has risks. Some equipment may be worn or abused, making it more difficult for a diyer unfamiliar with unknown problems with loaner tools.
Old 07-27-2022, 05:54 PM   #10
ronbo97
I tested #87 and there is 12V at that location. It's live all the time.
Next, I reinstalled the a/c relay, then determined that, yes, the cooling fan comes on when the a/c button is pushed.
Finally, I attached a line directly to the compressor pin after removing the blue connector. After starting the engine, I touched the other end of the line to the positive side of the battery. Nothing. No click. No movement.
So it appears that the clutch coil is toast.
I will opt to replace the entire compressor/clutch assembly, rather than trying to get at the clutch coil.
Next steps: Should I just buy a compressor, or do I need to replace the expansion valve, drier/accumulator as well ?
Note: Yes, I realize that I need the evacuate the system of R134a beforehand. I'll find a shop to do that, hopefully for free since they make $$$ on the recycled R134a.
Ron
Air conditioning not working SL1 dagolong S-Series General 9 05-31-2008 03:10 PM
Air Conditioning Not Working centerice Outlook General 2 04-25-2007 06:14 AM
Air conditioning working again Lurker1999 S-Series Tech 0 06-26-2006 08:17 PM
air conditioning not working Smiley1 S-Series Tech 10 06-11-2006 05:57 PM
