Old 03-22-2011, 09:32 AM   #1
x-angel
x-angel will become famous soon enough
x-angel's Avatar
2002 SL1
Default Fuel Pump 2011: PT3 - Bosch Fuel Sending Unit Part Number?
Does anyone know the part number for a Bosch Fuel Pump for a 2002 Saturn SL1?
Also.. is it possible that the sending unit from "Trademotion" be the same thing?
Thanks in advance!
Eric
2002 Saturn SL1
San Antonio, TX
x-angel is offline   Reply With Quote
Old 03-22-2011, 09:53 AM   #2
93sl1blue
93sl1blue is on a distinguished road
93sl1blue's Avatar
1993 SL1
Default Re: Fuel Pump 2011: PT3 - Bosch Fuel Sending Unit Part Number?
BOSCH Part # 69251-----this is just the pump
BOSCH Part # 67487-----this is the whole assembly.
if you buy the whole assembly, you need to move the sending unit from the old one and onto the new one. just did the fuel pump on a 1993 SL1 last week.
RockAuto has the best prices out of all the places i looked for parts.
try the junkyard for the sending unit. it will be used but will save you some money.
hope this helps
*Edit* although the pump and the sending unit are often refered to as the same thing, in my experience so far they are actually 2 different parts of the entire assembly. the sending unit here is refering to the "gauge sending unit". if your gas gauge is reading accurate then your sending unit is working.
93sl1blue is offline   Reply With Quote
Old 03-22-2011, 10:26 AM   #3
Thanks in advance!
Eric
Part #11 is the fuel level sender for the gauge. The pump unit is #8
Old 03-23-2011, 10:53 AM   #4
x-angel
x-angel's Avatar
2002 SL1
The main reason why this is is a conundrum is becuase of the way I install the pump.. I cut those stupid platic lines before realizing there was no sending unit on it. (I replace them with good rubber ones, and NO there are no kinks that could be cause my incessant fuel pump problems.)
Does the sending unit just slide on and off (on the bosch unut)? If it does... I am thinking about ordering one from NAPA that HAS the unit on it. Slide the Sending unit off, and then return that one as the unit that I bought (pump unit with no sending unit.)
Hows that sound?
2002 Saturn SL1
San Antonio, TX
Old 03-23-2011, 12:34 PM   #5
The sender is clipped on but it does come off.
Tags
bosch, fuel, sending unit, sl1 2002
Fuel Pump and sending unit L-300 01SatL300 L-Series General 7 07-11-2015 01:29 PM
FUEL PUMP or FUEL SENDING UNIT?.. saturn94v S-Series Tech 6 07-27-2008 10:40 AM
How do you remove fuel pump/sending unit? ringman S-Series Tech 9 02-27-2007 02:49 AM
Where can I buy a fuel sending unit for a 92 SL turbobuick33 S-Series General 5 08-28-2005 10:50 PM
Fuel Sending unit? SLeepr Miscellaneous Tech 2 11-07-2002 10:47 PM
