Old 07-22-2005, 06:47 PM   #1
rainking63
rainking63 is on a distinguished road
rainking63's Avatar
Default faint brake chatter
I'm getting a soft rattle from my front passenger side wheel when driving, (not just braking) and is condusive to the speed I am going (gets faster as I speed up, slower as I slow down).
I took off the pads, inspected them (minimal pad wear), the rotor, and the anti-rattle clips, and everything seems to be in order. The rotor is showing no signs of being grooved, and all the components seem to be spaced correctly.
After putting it all back together, the sound seems to be worse.
Is it the anti-rattle clips not living up to their name? Should I give in and just replace all the pads and clips?
Thanks for your help!!!
rainking63 is offline   Reply With Quote
Old 07-23-2005, 07:32 PM   #2
jambra1
jambra1 is just really nicejambra1 is just really nicejambra1 is just really nicejambra1 is just really nice
Default Re: faint brake chatter
You may want to take a peek at this thread to see if it helps generate any suggestions for you:
http://www.saturnfans.com/forums/showthread.php?t=48629
Is this a rattle or a clicking sound? Possibly anything related to CV joints?
jambra1 is offline   Reply With Quote
Old 07-24-2005, 12:10 AM   #3
peppermrj
peppermrj is on a distinguished road
peppermrj's Avatar
Is there any difference in wear between the inside and the outside pad?
peppermrj is offline   Reply With Quote
Old 07-24-2005, 12:30 AM   #4
M.Nguyen
M.Nguyen is on a distinguished road
M.Nguyen's Avatar
1993 SL2
Last time you had the tires balanced?
Rotated? could be cupped, or maybe something as simple as a rock stuck in the tread. hahaha...i've had that happen before.
M.Nguyen is offline   Reply With Quote
Faint whistling sound cam Vue General 15 05-13-2009 07:01 PM
Clutch chatter slv01sc2 S-Series General 8 09-29-2006 04:28 AM
Faint glunk Damins S-Series General 2 01-31-2006 06:10 PM
Faint, high pitched squeal when cold 94sc293sl1 S-Series General 15 05-20-2005 05:35 PM
clutch chatter fids187 S-Series General 6 08-13-2004 03:53 AM
