Old 04-29-2021, 03:38 PM   #1
BrandonKastning
BrandonKastning is a jewel in the roughBrandonKastning is a jewel in the roughBrandonKastning is a jewel in the roughBrandonKastning is a jewel in the rough
BrandonKastning's Avatar
2001 L-Series 3.0L Sedan
Wrench 2001 Saturn L300 (L81/3.0L V6) - Upper Radiator/Coolant Hose [Replacement]
This replacement hose was as difficult as I had expected.
You will notice that I end up moving the Throttle Body connector to the far left of the oil dipstick and then loosen the hose clamp to get it forward enough.
Make sure that you utilize "the ear" [thanks fdryer] that sticks out because it helps to use a pry bar to hold pressure toward yourself while "working" the hose on (the front part of the engine).
It's a tight squeeze; and not a lot of room to work with; therefore make sure that the bottom of the hose is as flush to "the ear" as possible.
* Make sure to remove the Front Engine Guard/Mount first; otherwise you cannot use a pry bar to the left of "the ear" which gives you the ability to not have the hose end being firm (which connects directly to the extension hose to our thermostat).
To be quite honest; I wanted to change it out anyways, then I was hoping I could remove the hose and use a rubber mallet to ensure the extension hose was fully knocked in the thermostat to ease my mind that I installed it correctly and I wouldn't have internal coolant leaks. Turns out; you cannot do this I found out today. I suppose it's fine and now I have a new Upper Radiator / Coolant hose.
Tool Needed:
  • Replacement Hose (New) [I used Gates]
  • Flat head screw driver (Medium size worked fine depending on your hose clamps; I changed all mine to flat head screw driver type, rather than using the special clamp types that I do not like. *Most certainly a preference thing here it seems by reading others posts*.
  • Pry Bar [Optional perhaps]
Thank you everyone!
Best Regards,
~ Brandon Kastning
~ TruthSword
WE THE PEOPLE ONLINE
http://wethepeopleonline.com
U.S. Const. Art. VI, Clause 2, 3 (September 17, 1787)
Here is Gallery Part.A from today:
“For God so loved the world, that he gave his only begotten Son, that whosoever believeth in him should not perish, but have everlasting life.” - John 3:16 (KJV)
BrandonKastning is offline   Reply With Quote
Old 04-29-2021, 03:39 PM   #2
BrandonKastning
Wrench Re: 2001 Saturn L300 (L81/3.0L V6) - Upper Radiator/Coolant Hose [Replacement]
Here is Gallery Part.B
Old 04-29-2021, 03:40 PM   #3
BrandonKastning
Here is Gallery Part.C
Old 04-29-2021, 03:41 PM   #4
BrandonKastning
Here is Gallery Part.D
Old 04-29-2021, 03:42 PM   #5
BrandonKastning
Here is Gallery Part.E
Old 04-29-2021, 03:43 PM   #6
BrandonKastning
Here is Gallery Part.F
Old 04-29-2021, 03:44 PM   #7
BrandonKastning
Here is Gallery Part.G
Old 04-29-2021, 03:45 PM   #8
BrandonKastning
Here is Gallery Part.H
Old 04-29-2021, 03:47 PM   #9
BrandonKastning
Here is Gallery Part.I
Old 04-29-2021, 03:48 PM   #10
BrandonKastning
Here is Gallery Part.J
Old 04-29-2021, 03:49 PM   #11
BrandonKastning
Here is Gallery Part.K
Tags
coolant hose, l300, upper radiator hose
2001 Saturn L300 (L81/3.0L V6) - Upper Intake Manifold + Spacer [Removal] BrandonKastning L-Series Tech 25 04-06-2021 11:03 AM
2001 Saturn L300 - v6 3.0 Liter - Water Pump Replacement (Coolant Question) BrandonKastning L-Series Tech 3 10-10-2020 04:40 PM
2001 Saturn L300 - v6 3.0 Liter - Draining The Radiator Fluid / Coolant BrandonKastning L-Series Tech 8 10-07-2020 11:49 PM
Can you replace the upper radiator hose without draining coolant? drunk horse S-Series Tech 4 07-04-2012 04:51 PM
Wow! I got lucky! My upper radiator hose blew! TIMSPEED S-Series General 11 02-02-2006 12:40 PM
