Old 04-08-2021, 02:28 AM   #1
BrandonKastning
BrandonKastning is a jewel in the roughBrandonKastning is a jewel in the roughBrandonKastning is a jewel in the roughBrandonKastning is a jewel in the rough
BrandonKastning's Avatar
2001 L-Series 3.0L Sedan
Wrench 2001 Saturn L300 (L81/3.0L V6) - Rear Camshaft Cover Gasket [Removal/Replacement]
Hey there everyone!
I have successfully removed the Rear Camshaft Cover with Gasket and did my very best to replace the rubber gasket with lots of High Temp O2 Safe RTV.
Torque Specs:
17 inch pounds (Rear Camshaft Cover Bolts)
Tools Needed:
  • Torque Wrench (Ratchet)
  • New Camshaft Cover Gasket
  • High Temp O2 Safe RTV
  • Q-tips (I used them for smearing RTV and keeping certain areas clean)
  • Gasket Scraper
  • Anti-Seize Lubricant (For Bolts)
  • Masking Tape / Electrical Tape (If you also wish to use it to hold pressure down on the rubber gasket to wet RTV)
  • Gunk Spray (To clean the oil off the Rear Camshaft Cover)
  • Wire Brush (To clean the oil off the Rear Camshaft Cover)
  • Rags (To clean the oil off the Rear Camshaft Cover)
This was quite difficult using as much RTV as I did. I used Q-Tips for cleaning or swiping too much RTV off; I most certainly didn't want to take any chances. The upper left corner that was leaking and had dry oil deposits. (I re-enforced this section with lots of RTV after cleaning it).
I will be letting this Rear Camshaft Cover dry all the RTV over night; then I will be proceeding to placing RTV on key spots on the Rear Camshaft (cleaned area from Gasket Scraper) and then re-assembling the Rear Camshaft Cover to correct Torque Specs.
Attached Pictures is Gallery A:
Best Regards,
~ Brandon Kastning
~ TruthSword
“For God so loved the world, that he gave his only begotten Son, that whosoever believeth in him should not perish, but have everlasting life.” - John 3:16 (KJV)
Last edited by BrandonKastning; 04-08-2021 at 02:29 AM. Reason: forgot to add styling
BrandonKastning is offline   Reply With Quote
Old 04-08-2021, 02:31 AM   #2
BrandonKastning
Wrench Re: 2001 Saturn L300 (L81/3.0L V6) - Rear Camshaft Cover Gasket [Removal/Replacement]
Gallery Part-B:
Old 04-08-2021, 02:32 AM   #3
BrandonKastning
Gallery Part-C:
Old 04-08-2021, 02:33 AM   #4
BrandonKastning
Gallery Part-D:
Old 04-08-2021, 02:34 AM   #5
BrandonKastning
Gallery Part-E:
Old 04-08-2021, 02:35 AM   #6
BrandonKastning
Gallery Part-F:
Old 04-08-2021, 02:36 AM   #7
BrandonKastning
Gallery Part-G:
Old 04-08-2021, 02:37 AM   #8
BrandonKastning
Gallery Part-H:
Old 04-08-2021, 02:38 AM   #9
BrandonKastning
Gallery Part-I:
Old 04-08-2021, 02:39 AM   #10
BrandonKastning
Gallery Part-J:
Old 04-08-2021, 02:40 AM   #11
BrandonKastning
Gallery Part-K:
Old 04-08-2021, 02:41 AM   #12
BrandonKastning
Gallery Part-L:
Old 04-08-2021, 02:43 AM   #13
BrandonKastning
Gallery Part-M:
Old 04-08-2021, 02:44 AM   #14
BrandonKastning
Gallery Part-N:
Old 04-08-2021, 02:45 AM   #15
BrandonKastning
Gallery Part-O:
Old 04-08-2021, 02:46 AM   #16
BrandonKastning
Gallery Part-P:
Old 04-08-2021, 02:47 AM   #17
BrandonKastning
Gallery Part-Q:
Old 04-08-2021, 02:49 AM   #18
BrandonKastning
Gallery Part-R:
Old 04-08-2021, 02:50 AM   #19
BrandonKastning
Gallery Part-S:
Old 04-08-2021, 04:06 AM   #20
BrandonKastning
Thumbs Up Re: 2001 Saturn L300 (L81/3.0L V6) - Rear Camshaft Cover Gasket [Removal/Replacement]
Something I forgot to mention. I was expecting small O-rings on the Camshaft Cover like it looks like. However; these ones on mine aren't soft rubber o-rings. They seem metal or some other type of material. I decided to leave them in place; since they seem to be doing just fine.
Tags
camshaft cover gasket, l81
2001 Saturn L300 - v6 3.0 Liter - Timing Belt Kit + Camshaft + Crankshaft Seals BrandonKastning L-Series Tech 777 09-06-2021 12:47 PM
2001 Saturn L300 (L81/3.0L V6) - Rear Camshaft Cover + Rear Guard/Mount [Removal] BrandonKastning L-Series Tech 15 04-07-2021 01:04 AM
2001 Saturn L300 (L81/3.0L V6) - Pre-Question for Head Gasket DIY Replacement BrandonKastning L-Series Tech 49 03-09-2021 01:11 PM
2001 Saturn L300 - Battery Harnass Removal Problem + Left headlight Removal Issue BrandonKastning L-Series Tech 14 02-26-2020 02:06 PM
2001 DOHC camshaft removal questionful S-Series Tech 3 10-28-2011 12:32 PM
