Old 11-03-2018, 04:58 PM   #1
rabbit1985
rabbit1985 is on a distinguished road
Default Shifter cable installation help!
I have pretty much everything installed but am having a heck of a time getting the cables attached to the metal bracket that attaches to the bell housing of the transmission. Tried a few things that were probably a little risky but can't quite get em. I know that they are spring loaded and are supposed to slip back to get em on the bracket but this new set is stiff and I can't get em back when trying to mount. Any tips or tricks?
rabbit1985 is offline   Reply With Quote
Old 11-05-2018, 02:12 PM   #2
Beasleylou
Beasleylou is on a distinguished road
Default Re: Shifter cable installation help!
I presume you are referring to the plastic ball joint type connectors at the ends of the cables. They should snap securely over the balls on the bracket. Iirc, Very little force required.
Make sure you have the cable adjusters loose on the inside so there is no stress on the cables when you are fastening to the transmission.
Beasleylou is offline   Reply With Quote
Tags
shift, shifter cable, transmission
Audio dash installation question (antenna cable) craz3dmedic Ion General 1 04-09-2015 02:22 PM
Emergency Brake Cable Installation Dilema Ramics S-Series Tech 10 01-22-2014 11:28 PM
Shifter Cable to Shifter Tower cCnnections Spaghettiohead S-Series Tech 13 12-08-2012 02:36 PM
can't get shifter cable off!!! need help penleydr S-Series General 2 03-28-2005 04:19 PM
