Old 05-27-2017, 03:17 AM   #1
Littleman
Littleman is on a distinguished road
1994 SC2
Default Transmission cooler line - broken disconnect
94 SC2 Upper automatic transmission line cracked and replacement came in today. When trying to remove the line from the transmission with the quick disconnect, I wasn't able to get it off. I read that it ranges from simple to requiring pliers to squeeze, but I think the AD is broken. It swivels easily while the other line's is pretty firmly fixed in place.
So, if the plastic disconnect is broken, how can I remove the line? And can I buy another clip? The replacement line didn't include one. Thanks
Littleman is offline   Reply With Quote
Old 05-27-2017, 11:38 AM   #2
bachands
bachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to behold
Default Re: Transmission cooler line - broken disconnect
The quick-disconnect just holds/locks it in place. So if has broken somehow, then there's nothing holding the line in there except rust/corrosion. Spray some PB Blaster in the connector and try twisting the line back and forth. Continue this until it becomes loose enough to pull out.
If the connector is that rusted, I recommend a new one. They will come with a quick-disconnect. Below is a link:
Trans Cooler Line Connector
Auto parts stores do have replacement quick-disconnects. They are usually made by Dorman, however, they are not as good of quality as the originals.
'97 SL1, 136K, Auto, Mint Green (SOLD 146K)
'99 SL2, 126K, Auto, Silver (SOLD 149K)
'97 SL1, 136K, Manual, Burgundy (Gifted to Brother 138K)
'02 SL2, 149K, Auto, Light Gray/Silver
bachands is offline   Reply With Quote
Old 05-27-2017, 10:46 PM   #3
Littleman
1994 SC2
Thanks for the part link. I realized I have something else entirely happening in their. It looks like a previous owner or mechanic made some mods. The reason the disconnect wasn't working is that it wasn't even engaged. The cooling line was swaged at the end with a compression fitting. No wonder I couldn't figure out how the plastic QD was supposed to work. Looks like I'm going to be crawling the junkyard tomorrow or waiting for another RockAuto shipment to take this back to stock. Thanks again.
Old 05-28-2017, 12:09 AM   #4
bachands
Compression fitting on the trans end?! How is that even possible?!
But hey, I've seen some strange things that people have done...both on this site and on the Saturns I've owned.
Transmission cooler line routing RichNH Astra Tech 0 05-20-2016 01:01 AM
Transmission Cooler Line Connector dave380 Ion Tech 0 06-04-2015 03:09 PM
Transmission cooler return line Mark121 S-Series Tech 2 02-22-2015 04:17 PM
Small transmission fluid leak from radiator transmission cooler line EvanVanVan S-Series Tech 5 10-13-2014 07:55 PM
Adding a transmission cooler- is this what I need to disconnect? joshjani Vue Mods 11 08-05-2009 10:42 PM
