Old 03-02-2012, 11:32 PM   #1
aardwlf
aardwlf is on a distinguished road
2001 SL2
Default 2001 Saturn Manual Conversion
I have a 2001 Saturn SL2 automatic, and a 1998 Saturn SL2 manual(donor car) I have begun the tranmission swap from the 98 to the 01, I've scouted out a few cars at junk yards and found a 2000 SL2 manual. Should I get the PCM from that car as well? Must the options match up on 3rd gen or can that be reprogrammed? Also should I grab the BCM from that car as well as the PCM?
I plan to finish the mechanical half of the swap tomorrow, I guess I'll figure everything out one way or another.
aardwlf is offline   Reply With Quote
Old 03-03-2012, 06:44 AM   #2
Gold Saturn
Gold Saturn is on a distinguished road
2000 SC1
Default Re: 2001 Saturn Manual Conversion
Everything programs except for the manual option, so yes, grab it. You might even get lucky and won't need to program it...I got a box off of ebay and plugged it into my car and it worked...saves me $90 on a flash. You don't need a different BCM, just follow the PCM passlock relearn procedure and you're good. I just did a manual swap 2 months ago, swapped a 5 spd into my 00 sc1 from a 95 sl1.
2000 SC1, 5 spd swapped @ 133k, totaled by drunk driver @ 165k, RIP
Gold Saturn is offline   Reply With Quote
Old 03-03-2012, 07:04 AM   #3
aardwlf
2001 SL2
thanks! I thought that was the case, but I saw one member who did this swap and changed both the PCM and BCM and it got me wondering... here I go, out to start pulling the manual.
Old 03-04-2012, 10:06 AM   #4
Gold Saturn
2000 SC1
I suppose you can if you want to, seeing as the BCM is what stores the mileage information in the later years...perhaps if you find a low-mileage BCM you can make some resell profit? Regardless the BCM is tricky in that it needs to have the exact options your car has (power windows, locks, etc) I used the PCM with my current BCM just fine by following the passlock relearn. Haven't had any problems with it since.
Old 03-07-2012, 12:35 AM   #5
aardwlf
2001 SL2
well, that was a fun time.. took it out for a drive for the first time today...Did you're car have ABS? mine did and the abs unit was in the way of the clutch master cylinder.. i had to move it forward about an inch or to fit the clutch master cylinder in there...(drill&tap new holes) surprisingly, the battery and PCM still fit!
Old 03-07-2012, 07:24 AM   #6
3rd gens must be different then 1st gens, when I had a '93 SL2 I didn't have to move anything to fit the clutch master cylinder in (let alone drill & tap anything), though the ABS module was fairly annoying to work around.
Old 03-07-2012, 07:54 AM   #7
aardwlf
2001 SL2
Maybe the 2000-2002 master cylinders are a bit smaller? I used the 2nd gen hydraulics and there was no way that was going to fit. I can post pictures if anyone wants.
97 Saturn SC2 Automatic to manual conversion? RET80 S-Series Tech 17 02-21-2015 09:50 PM
manual conversion not computing ? kenneth683 S-Series Tech 3 05-31-2010 11:08 PM
2001 Saturn L100 2.2L Manual Transmission Headaches cybercyst L-Series Tech 5 11-24-2006 09:28 PM
need a user manual for a 2001 Saturn L200 Tippy L-Series General 2 08-15-2006 12:03 AM
conversion from auto to manual 06lev3x4 Ion General 11 06-04-2006 10:06 AM
