Old 06-27-2012, 01:00 PM   #1
saturn hippie
saturn hippie is on a distinguished road
Default p0303 after rebuild, rough idle
Did a rebuild on my 01 SL1 SOHC, and now I am getting the p0303 misfire on cyl. 3 and it idle incredibly rough. I have checked all my plugs, wires, injectors, and have sprayed brake cleaner around the intake gasket to check if the seal is good. None of these has solved my issue thus far. Does anyone have any other suggestions on what to do?
saturn hippie is offline   Reply With Quote
Old 06-27-2012, 02:15 PM   #2
Default Re: p0303 after rebuild, rough idle
Spark test on cylinder #3? Swapped ignition coils around? Verified #3 injector wetting plug #3? Compression test even after the rebuild? Checked fuel pressure?
Old 06-27-2012, 02:46 PM   #3
saturn hippie
Have good spark on all cylinders, compression is 180 plus across the board, thought the #3 injector might have been the culprit, but after cleaning all of them and swapping then around the conditions persist.
Old 06-27-2012, 05:07 PM   #4
ssewall
ssewall is on a distinguished road
Plug wires in the correct order? 1234->4123.
Have you checked to see if there's actually current going to the #3 injector?
How are you determining that the spark is good?
ssewall is offline   Reply With Quote
Old 07-01-2012, 01:02 AM   #5
saturn hippie
Plug wires are in the correct order. It is my understanding that if the 2-3 ignition coil is having issues then both the 2 and 3 cylinders will have issues. The #3 plug looks like it is burning uneven.
Old 07-01-2012, 01:28 AM   #6
magtec
magtec will become famous soon enough
1995 SW2
how's the fuel pressure? #3 tends to be the first cylinder to run lean.
magtec is offline   Reply With Quote
Old 07-01-2012, 01:07 PM   #7
1sksc2
1sksc2 has a spectacular aura about1sksc2 has a spectacular aura about
1996 SL2
180+
from what i know about these motors, shouldn't be around 200+ after a rebuild.
1sksc2 is offline   Reply With Quote
Old 07-01-2012, 01:38 PM   #8
magtec
1995 SW2
yeah, compression should be 200+ (180 is the service limit, iirc). depends on how the test was performed, though.
Old 07-01-2012, 01:58 PM   #9
Compression is compression, whether its 180 or 220psi. Ensuring that your rebuild is mechanically correct eliminates pistons, rings, valves, and timing. All by posting another compression test. Move on. Its not a mechanical issue with the engine running rough.
Reusing the old ignition system, fuel pump, fuel filter, sensors, all, can contribute to erratic engine running. The trick is to start eliminating each one according to either a logical sequence, price, used/new parts availability, common sense. Ignition control modules and coils from a junk yard are the way to go. A fuel pressure test can help with any fuel system issues. Sensors will have to be examined one at a time for their importance in relation to specific issues.
Old 07-01-2012, 02:12 PM   #10
1sksc2
1996 SL2
uneven compression can make a engine run like crap. you should know this of all people on here.
my sl2 has all sensors performing as should. yet at idle i am running rough.
my compression is bad and will be needing a rebuild.
ive been on this site talking with oldnuc in PM's for a long time. and we have discovered that the sensors are fine. all wires and connections are fine. most of my sensors, connectors, are new. even a new freshly flashed pcm from the dealer is new. new cylinder head, new timing set, coils, plugs and wires.
this man needs to do the proper compression test everyone else does and it should be thought about after that.
Old 07-01-2012, 02:15 PM   #11
1sksc2
1996 SL2
another question. where you having any problems like this before you rebuilt the motor.
Old 07-01-2012, 02:32 PM   #12
Every engine rebuild is different from the other and making comparisons gives you tunnel vision without accepting the possibilities of other issues. Since when does one rebuild mean that the sensors on one engine is the exact same sensors on this engine? Do you see the tunnel vision yet? There's no one expert anywhere.....................
When you compare one engine rebuild to another then you already developed tunnel vision. Every engine rebuilt is not the same.
Old 07-01-2012, 02:44 PM   #13
1sksc2
1996 SL2
all im saying if there was no problem to being with before he rebuilt the engine then there shouldnt be any problems now.
i believe there is a mechanical problem.
just have to wait for some answers
Old 07-01-2012, 02:53 PM   #14
If it makes you feel any better then a dry and wet compression test can be done and accept what's posted and move on.
Old 07-01-2012, 02:59 PM   #15
1sksc2
1996 SL2
sounds like a deal to me.
remember its a learning process for some of us. i will except it if im wrong and learn from it.
Old 07-01-2012, 03:02 PM   #16
Hey, even 'experts' learn too..................for those that don't have big heads.
Old 07-01-2012, 10:27 PM   #17
saturn hippie
The compression test was performed dry, i put a bit of oil in each cylinder and did the test again they were all around 210 +/-5. have to borrow a fuel pressure gauge from the parts store tomorrow. The reason for the rebuild was i blew the head gasket, drained 2 quarts of oil, and the #3 rod bearing fused itself to the old crank.
Old 07-01-2012, 10:38 PM   #18
Let's move on now that we understand there isn't any mechanical issue.................
Old 07-02-2012, 03:53 PM   #19
1sksc2
1996 SL2
my apologies.
Old 07-02-2012, 07:10 PM   #20
saturn hippie
Fuel pressure is 45 psi at the schrader valve.
p0303, rough idle
97 SC2 5 speed - Rough Idle & Rough Start Jyounya S-Series General 2 07-05-2011 03:58 PM
Rough IDLE/Low IDLE no check engine light savage21 Vue Tech 9 12-08-2010 01:27 AM
rough idle bdobraj S-Series General 37 06-29-2009 01:59 PM
really rough idle when in 1st gear at idle rpqsl S-Series Tech 4 12-06-2005 09:25 PM
rough idle, rough sluggish pickup, 97slw smiles233 S-Series General 7 10-14-2005 04:28 PM
