Old 03-27-2008, 10:57 PM   #1
Surfing_Monkey
Surfing_Monkey is on a distinguished road
Default Clutch Hydrolic Help
So my car started getting hard to put into first gear. And when at a stop light if left in gear with the clutch in it felt like it was trying to go. So I replaced the Master cylinder/Hydrolic unit. It felt good for a day then same issue. I pulled the unit out and the two plastic placment tabs had come off and the rod was all the way out. The tabs werent broken so I placed them back in the clips and put it back together. As soon as I pushed the clutch in I could hear the clips pop out again.
Did I just get a faulty unit or am I doing something wrong? Any help is appreciated.
Surfing_Monkey
Surfing_Monkey is offline   Reply With Quote
Old 03-28-2008, 12:06 AM   #2
Squareback
Squareback is a jewel in the roughSquareback is a jewel in the roughSquareback is a jewel in the roughSquareback is a jewel in the rough
Squareback's Avatar
2005 ION-2 Sedan
Default Re: Clutch Hydrolic Help
H-y-d-r-a-u-l-i-c
The plastic clips are there as a one time use to keep the rod in place before the hydraulics are installed the first time. Once you hit the pedal the first time, the clips break. That is their only intended purpose. Did you actually test your old hydraulics and make sure they were faulty or are we just throwing parts at it hoping it fixes the problem?
Certified Saturn Technician
Squareback is offline   Reply With Quote
Old 03-28-2008, 02:40 AM   #3
rc1488
rc1488 has a spectacular aura aboutrc1488 has a spectacular aura about
rc1488's Avatar
Always post your vitals in every new thread
Your problem points to a worn pressure plate NOT fualty hydraulics (originally, however now it may be both).
Youve pretty much just stated you failed the creep test along with having a hard time to get into first gear. A new clutch assembly is in order
Current: 95 SC2 Man 97 SL2 Auto 98 SL1 Auto 01 SL1 Man 02 SL1 Man
Past: 94 SL2 Man 95 SL2 Man 95 SL2 Man 96 SL2 Auto 97 SL2 Man 98 SL2 Auto 99 SL2 Auto
2010 SCCA Mohud Street Championship-2nd Place
rc1488 is offline   Reply With Quote
Old 03-28-2008, 08:48 AM   #4
DonP
This thread has a graphic the shows clutch hydraulics diagnostics, and will help differentiate among possible problems.
http://www.saturnfans.com/forums/showthread.php?t=91924
Old 03-28-2008, 01:20 PM   #5
Surfing_Monkey
Thanks for the help. Sorry about the spelling I am not smarter than a fifth grader.
Old 03-28-2008, 03:08 PM   #6
DonP
As a new member (welcome), and if your car is 2001 or older, be sure th check the ECTS (and connector) as a good preventive measure. See the first two threads in the How-to Library forum for details.
Aura - Hydrolic Steering Defect AuraCanada Aura General 7 08-08-2012 09:15 PM
Clutch Fork related to clutch problems? MikeNW S-Series Tech 0 06-25-2008 01:27 AM
hydrolic Lifters mark_92SC2 S-Series Tech 8 01-07-2006 06:34 PM
Clutch fluid level, clutch pedal vibration, small leak Heartbeat - '95 SL2 Miscellaneous Tech 10 10-10-2003 06:35 PM
difference between clutch actuator and clutch master/slave cylinder geartooth94 S-Series Tech 3 06-10-2003 12:36 PM
