Old 05-23-2021, 03:39 PM   #1
Ccrussell
Ccrussell has a spectacular aura aboutCcrussell has a spectacular aura aboutCcrussell has a spectacular aura about
1999 SL1
1999 SC2
Default Sl1 trans shift trouble after rebuild
Hello
This is my hi mile,SL1 car that just got an
Engine rebuild after 352k miles.
This trans issue began about 400 miles after the engine rebuild .
Started to shift hard first into 2nd, hard shift into 3rd,also but not as much bang as 1 to 2.
Changed the trans oil and filter in the transmission but problem persists. Disconnected battery cable for 10 minutes made no difference fuses TR1,TR2 appear to be intact any thoughts? Will a used trans be coming along soon?
Transmission has never been touched other than routine oil and filter changes 352k on it also. Once the car is up the highway speed it just purrs along very nice.
Transmission downshifting is also a bit rough but not as pronounced.
This is not to be confused with my SL2 that I am waiting on a connector for thevalvebody . That’s a different post
Ccrussell is offline   Reply With Quote
Old 05-23-2021, 04:01 PM   #2
Default Re: Sl1 trans shift trouble after rebuild
Did you check the 3rd tans fuse? Also, check the resistance on all (5) trans solenoids. Check system voltage with engine running (should be 14-15VDC)
After those easy ones, probably time to use a gauge to check trans line-pressure.
Old 05-23-2021, 07:18 PM   #3
Ccrussell
1999 SL1
1999 SC2
Ok
I checked the three fuses , all good .
Voltage at battery while running; 14.4 vdc.
This trans has always been super reliable , babied mostly.
Going to read up on reading the resistance next thanks.
Russ
Old 05-25-2021, 08:35 PM   #4
Ccrussell
1999 SL1
1999 SC2
Hello,
Ok this is where I am:
I changed transmission oil, as I had overfilled the transmission by approximately 1 quart. Realizing this, I drained the oil ,changed the filter with a WIX ,and refilled the transmission with the correct level of oil. The used oil had sludge in it however the oil was dark red did not smell burnt and had no signs of any metal contamination. I would be ashamed to tell you how many miles it had on it since it’s last change
No change in shifting.
Tonight I checked the terminals on the valve body and discovered that terminal F & G which I presume is line pressure is reading at a low 2.1 ohms.
All the rest are reading 5 ohms or greater.
I have a spare used valve body , from Which I will source a coil, change out ASAP and post results.
Feeling pretty confident that this may be the solution.
Old 05-25-2021, 10:10 PM   #5
bluesl2
bluesl2's Avatar
Line pressure solenoids on the later years of the S-series were kind of problematic. That resistance reading of 2.1 ohms is enough to make a difference in shifting. I bet changing that fixes it.
Old 05-25-2021, 10:21 PM   #6
Yes, F and G are the LP solenoid.
All five of those solenoids are the same P/N, so take whichever you want from the spare VB.
03 Saturn Ion Shift knob trouble DrewMan Ion General 3 07-12-2013 09:49 PM
OEM S-Series Manual Trans Shift Knob / Auto Trans Selection Handle Options/ Removal Saturninin S-Series General 1 02-22-2013 12:45 AM
03 awd 2.2 trans rebuild roblamb Vue Tech 2 02-15-2012 12:12 PM
Where do you get new parts for a trans rebuild? Mgg4591 S-Series General 26 03-19-2011 04:52 PM
Overfilled trans Fluid, now TC not lockout. Is Total trans rebuild ahead? 62morgan S-Series Tech 14 02-23-2009 09:30 AM
