![]() ![]() ![]() Join Date: Jan 2019
While at a stop light, if I let the car roll a foot or 2, then step on the brakes, then let off the brakes, then step on the brakes again at a 1 hertz rate. I hear a pretty loud creaking noise.
The car has only 63k original miles but when I bled the brakes 2 weeks ago, I noticed a lot of rust on the suspension. I have not crawled under to investigate yet. Any guess as to what is making the noise? Can someone please post a link to the FSM rear suspension diagram? fdryer?
1/28/2019 2002 SL2 w 62k miles |
I think post 4 has bumpdraft's picture but I cant see it because the site is blocked at work
http://www.saturnfans.com/forums/sho...d.php?t=184941 Should be some pics here (hunt4steve) but again, I cant see them ![]() http://www.saturnfans.com/forums/sho...d.php?t=203651 http://www.wholesalegmpartsonline.co...24ZZ07-001.JPG
I'm not worthy to grovel in the shadow of Signmaster's wisdom 11/2016 red 2002 5 spd SC2 151k DD 12/2008 eBay silver 1998 SL2 5 spd 102k, now 201k+ miles |
It's likely the shoes just need to be lubricated where they slide on the backing plate.
I'll have to take the drum off to check that out. Do you have the FSM chapter on taking the drum off? I think I have to retract the shoes first by turning a star wheel.
#5 | |
Gotta say Saturn must have used cheap metallurgy in building their cars. The knuckles on my 92 VW Jetta and 83 Mercedes 300 D has a lot less rust than my 02 Saturn SL2!
The FSM literally says release parking brake, remove wheel, then remove drum.
The access hole for the wheel was designed by a dyslexic, it's on the wrong side of the axle center-line on both sides (so the normal tools don't reach it). I don't remember off the top of my head which side spins which way to tighten/loosen the shoes, you may have to experiment with it (spin it a few times, if the wheel doesn't spin that was the wrong direction...when you're done you want it to stop the wheel after 2-3 full turns). |
Creaking Noise While Braking | sublimefool311 | S-Series Tech | 9 | 09-15-2013 12:14 PM |
Rear knocking noise when braking | tapatia | S-Series Tech | 10 | 07-16-2007 11:56 AM |
creaking noise in right rear | vintagegz | Vue General | 14 | 01-04-2007 01:56 PM |
Creaking noise from rear wheel well | Krusen04 | S-Series General | 8 | 04-01-2004 05:36 PM |
low brake pedal and noise from right rear upon braking | mykidssaturn | S-Series Tech | 4 | 10-20-2002 11:22 PM |
