#1 |
![]() ![]() ![]() Join Date: Jan 2019
I bled all 4 wheels today, fluid was nice and clear. I wanted to take the front calipers off to clean the rust that's binding the pads but did not have replacement brake pad clips, which are really rusty and not functional anymore. So I did not take them off.
The pads are 1/2 worn so I may as well get new pads and do it next time. Are these Autozone pads https://www.autozone.com/brakes-and-...4_116848_16108 with clips ok? It has limited lifetime warranty which I think means I will never have to buy them again. Just bring the old ones in and exchange for new ones. Is that right?
1/28/2019 2002 SL2 w 62k miles |
#2 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2016
Anything is ok. I have the Centric 90862072 rotor and pad kit on both of my Saturns. The '98 has about 10000 miles on the brakes and the '99 has about 40. I would never just replace the pads.
#3 |
Are you aware that using the old rotors with new brake pads may take longer to bed in pads? Rotors wear down along with brake pads. It's prudent to machine rotors, if they're not worn down to minimum thickness, to have both surfaces parallel in preparation for new pads. Parallelism can't be seen visually. Rotors wear down unevenly and may have ripples, undulations and taper that would not allow new brake pads to bed in quickly as opposed to new or machined rotors.
#4 |
I have done my own brake work forever and never turned or teplaced a rotor except on onethat had a small hairline crack. Sure, new or turned rotor is best but as long as the rotor meets min thickness and not warped, it's good enough for me. Before anyone think I am wreckless, I am a safe driver with a perfect driving record.
#5 |
This isn't about safe driving but being aware of using new disc brake pads on used rotors and the issues of mismatching/misalignment between worn rotors with new brake pads. Its always a personal choice with no one pointing fingers. I've done this in the past once or twice but no more. I'm not sure but rotors don't seem to have much meat on them when new so the last time I miked rotors, they appeared made for one time use - wearing down a set of brake pads doesn't leave much left for machining for reuse so I decided to replace rotors and brake pads at the same time. Each situation has its own set of issues that must be considered on it own merits. Include costs for brake lathe machining and replacing rotors seems less costly to replace.
#6 |
![]() ![]() ![]() ![]() Join Date: May 2011
I always replace rotors when I replace pads...
I also replace drums and new hardware kit when replacing shoes... Look on Rock Auto for good prices... or EBC brakes for different pad materials... Black, Yellow, Green, or Red...
2002 Silver SL2, manual, 5th gear swap (.605), 80,000 miles, black badges, 205/60R15 "H" rated tires, 5mm spacers rear... Pennzoil Maximum Power 0W-30, Champion COS3600... NGK BKR6E-11 spark plugs |
#7 |
EBC brakes...
https://www.autoanything.com/brakes/ebc-brake-kits
#8 |
I have never owned a car with vented rotors till this Saturn. Maybe vented rotors wear out faster? What is the min thickness?
#9 |
![]() Join Date: Aug 2019
#10 |
FSM:
New - 0.71inBe careful what color EBC pads you get, most of the time Green is all the S-Series needs. Either yellow or red is a race pad that has no grip before being warmed up while the other is a HD pad meant more for Trucks & SUV's hauling stuff. |
#11 |
Going with Autozone limited lifetime pads is a no brainer for me. Buy it once and never have to buy it again.
#12 |
Personally, vented rotors on daily economy cars are window dressing. Whether or not they wear out brake pads is up for debate as I would imagine if they do wear out brake pads the supposition is that braking is stopping the car where driver and passenger are thrown forward all the time........
#13 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2013
I have some (vented) rotors in use that are 50 years old. Stick with your common-sense here. If the braking is fine, just replace worn pads/shoes.
You will never notice the difference in braking, as the friction surfaces wear in, without sophisticated instrumentation. |
#14 | |
![]() Quote:
This is the first time I hear of the recommendation to replace the pads and rotors together.
#15 |
#16 | |
![]() Quote:
#17 |
I may have a set in the trash I could part with. Brake pads too.
#18 | |
![]() Quote:
While everything was apart, I took a hammer and screwdriver to knock off the thick scaly rust on the wheel knuckle then coated it with wheel bearing grease to prevent further rust. Can't believe how must rust came off! I took some pics which I will post later.
#19 |
If I had new rotors, I would have installed them. Next brake job definitely. Knocked off lots of rust!
#20 |
Coated with wheel bearing grease to stop further rust.
Bookmarks |
Front Struts and hardware availability issues | FieroAlex | Astra Tech | 82 | 12-20-2021 11:43 PM |
Disc Brake Hardware KIT Front | Samtherecordman | Ion Tech | 5 | 05-22-2016 02:42 PM |
2002 SL2 front brakes upgrade? | silversaturnsl2 | S-Series Tech | 10 | 09-03-2015 09:38 AM |
front disc brake hardware?? | scalemechanic | S-Series General | 5 | 01-19-2013 12:46 AM |
2002 Sl1 Front Brakes | B.S.T. | S-Series General | 4 | 03-18-2008 12:52 PM |
