Old 02-15-2022, 07:15 PM   #1
deweyfrady
deweyfrady is on a distinguished road
Default 2002 2.2 Ecotec timing Question
I have a 2.2 Ecotec that the timing chain broke on. I did not note the crank position before pulling the balance shaft chain to replace it. How do I determine if the #1 piston is at TDC on the correct stroke to install the timing chain and balance shaft chain?
deweyfrady is offline   Reply With Quote
Old 02-15-2022, 11:04 PM   #2
02 LW300
02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold
02 LW300's Avatar
2002 L-Series 3.0L Wagon
2002 L-Series 2.2L Sedan
Default Re: 2002 2.2 Ecotec timing Question
It is easy to determine after you replace all the bent valves.
2002 LW 300 loaded, only 95,000 original miles!
2002 L200/5 Loaded, over 1/4 million miles!
2000 LS1, TMU love those bcm failures.
Old 03-14-2022, 12:45 PM   #3
rfisher
rfisher is a jewel in the roughrfisher is a jewel in the roughrfisher is a jewel in the roughrfisher is a jewel in the rough
hi sages - regarding the bent valves resulting from a busted timing chain in the 2.2 L 4 cyl engine wouldnt the short cut remedy be to replace the wrecked head with a used or rebuilt complete cylinder head? also wouldnt giving the job to a dealer or even an indy be an invitation to the cleaners? bet that job would cost $1k. remember there are people who will pat you on the back with one hand and pick your pocket with the other. maybe i need attitude readjustment hour. thanks tons bob f
rfisher is offline   Reply With Quote
Tags
2.2 ecotec, ecotec, help please, timing, timing chain
2008 Vue ecotec question. Timing chain replacement questions. RCRV Vue Tech 0 11-19-2019 03:22 PM
2.2 ecotec timing question rocket321 L-Series Tech 10 07-29-2015 01:36 PM
2002 saturn 2.2 ecotec /2010 cobalt 2.2 ecotec dirtydawg Vue Mods 5 07-01-2014 09:20 AM
2.2 ecotec timing chain question 2.2ecotec L-Series Tech 17 02-12-2014 11:38 AM
2.2l Ecotec timing question elviec Mods and Performance 2 02-15-2005 04:04 PM
