Old 08-12-2011, 01:13 PM   #1
dapper
dapper is on a distinguished road
2002 SL1
Question can bad catalytic converter cause power and trans. problems
Own an sl1, 82k, bought used about 3 years ago. Have severe power problems, sometimes having problems going up even modest hills. Also recently, problems going into reverse (hard reverse, 1-2 sec. delay), going from 2-3 gear, and sometimes from 4-5 gear. took to transmission shop, after some time, came up with 2 problems. valve body for trans, and a partially clogged catalytic converter. he got codes for the solenoid (valve body), and a voltage drop (which he traced to corrosion on battery). Question, can the clogged converter be the only problem? I know it can cause power problems, but could it also be the cause of my 'seeming' trans. problems? He had to order the part, so it's not going to be done until tuesday, and I called another exhaust shop, and tomorrow morning he's going to check out the converter. He recommended holding off on any trans. repairs until converter problems is addressed. Any ideas? Thanks.
dapper is offline   Reply With Quote
Old 08-12-2011, 02:29 PM   #2
ehunter
ehunter has a spectacular aura aboutehunter has a spectacular aura about
Location: Pacifica by San Francisco – 5sp – Original engine rebuild as documented by this site @ 177K due to high oil consumption. Mpgs back to 40+. Car runs smooth, like a top. Now at 220k. Successful rebuild !
1996 SL2
Default Re: can bad catalytic converter cause power and trans. problems
modify your profile so your make/model and region you live in automatically show up under your name on the left of these posts.
Remove your O2 sensor from your exhaust manifold and see if your power comes back. It will make quite a racket when you drive this way but it will tell us where we should be looking for a problem.
ehunter is offline   Reply With Quote
Old 08-13-2011, 10:17 AM   #3
dapper
2002 SL1
Just got back from the exhaust shop; turns out the cat.converter is just fine, as is the entire exhaust system. he forgot to check the O2 sensors, they will do that monday, when they have an ase-certified mechanic on duty. I scheduled a diagnostic visit to see what he will find. I'm going to put off replacing the valve body until the results come back on this next visit.
Old 08-13-2011, 01:21 PM   #4
ehunter
1996 SL2
When was the last time you had a tune up? If you dont believe that may be the issue, I would do a compression test.
Old 08-13-2011, 08:06 PM   #5
dapper
2002 SL1
in terms of tuneup, I replaced plugs and wires at 70k, nothing else in that area. something new, the 'service engine soon' light just came on; hopefully this will point the way when its' checked out monday. I will ask them to do compression check. thanks.
Old 08-22-2011, 09:39 AM   #6
dapper
2002 SL1
the code I was getting was P0410. just came back from fasttrack (formerly my saturn dealer). The vacuum hose going into the air-pump (may not be describing it properly) had deteriorated-had a slit in it, and was almost ready to break off. He also checked O2 sensor, and did back-pressure-everthing good. Car runs much better now, and he suggested I not get the valve body replaced just yet. On the way home, the car shifted just right, and managed to climb some hills (for this car, that's a home-run!). so I'm going to wait, the 1st test will be tomorrow morning when car is cold, and I shift into reverse. If that's OK, then I might not need the valve body, after all. It's still hard for me to imagine any mechanic pointing a finger at the valve body without checking out other items that would also cause shift problems. But we'll see--will let you know. many thanks!
Old 08-29-2011, 07:30 AM   #7
dapper
2002 SL1
Question Re: can bad catalytic converter cause power and trans. problems
Car ran great for 4 days-put 150 miles on it, shifted fine, even in reverse. On the 4th day while on the highway, I went to pass a truck, going around 55, stepped on accelerator, car 'jumped or lurched', would not engage in lower gear. Since then, car behaves like it did before, hard-reverse and all. It also sounds much louder and the power/performance problem seems to be back-but not quite so bad. I'm going to call fasttrack again, to set up another appmt, but boy, this is getting expensive. Before I go in, can anyone give any advise or thoughts why this car would perform great for 4 days, then all of a sudden, bang! If the valve-body is bad, how could it perform well for 4 days?? Thanks, again!
Old 08-29-2011, 09:30 AM   #8
Were all the vacuum lines checked for dry rot/deterioration and replaced to rule out any vacuum leaks?
Did you ever check fuel pressure with a pressure gauge?
VCX NANO
Old 08-29-2011, 10:33 AM   #9
richbrad08
richbrad08 is on a distinguished road
Catalytic converters don't typically fail, but they can become clogged.
Tachometer
Decreased engine power--indicated by low revolutions per minute (RPMs) on the tachometer--is a symptom of a bad catalytic converter.
Acceleration
Another sign of decreased engine power is hesitating or bucking when you try to accelerate.
Driving Uphill
The car may seem to lose some power when going uphill.
Temperature
If the engine runs hotter than usual but the cooling system is up to par, that may indicate catalytic converter problems.
Exhaust
Black smoke coming from the exhaust pipe may be a symptom of a bad catalytic converter.
Smell
A failing catalytic converter can cause a rich fuel mixture that makes the exhaust smell like rotten eggs from the hydrogen sulfide.
Read more: What Are the Symptoms of a Bad Catalytic Converter? | eHow.com http://www.ehow.com/facts_4856391_sy...#ixzz1WQcy7Duu
richbrad08 is offline   Reply With Quote
Catalytic Converter Problems on L300 BigDaddyGuns L-Series Tech 12 08-23-2010 04:56 PM
Help! 02 L300 catalytic converter problems apejig L-Series Tech 10 01-11-2008 10:32 PM
Problems with Catalytic Converter-2005 2NDSOUT Vue General 7 08-13-2005 11:56 PM
Catalytic Converter myoung S-Series Mods 10 05-05-2003 08:07 PM
Catalytic converter. saturnmanSC2 S-Series Tech 17 02-09-2003 12:53 AM
