Old 06-16-2020, 10:26 PM   #1
BrandonKastning
BrandonKastning is a jewel in the roughBrandonKastning is a jewel in the roughBrandonKastning is a jewel in the roughBrandonKastning is a jewel in the rough
BrandonKastning's Avatar
2001 L-Series 3.0L Sedan
Wrench 2001 Saturn L300 - v6 3.0 Liter - Fog Lights (Parking Ones)
Has anyone else had problems with their Fog Lights just randomly not working regardless of fuses?
I have checked all the fuses; I replaced the bulb that I pulled out to test and will replace them both at the same time.
Are there any other places I could look or causes that could prevent the Fog Lights / Parking Lights from turning on when the engine starts?
This used to be automatic for me!
Any point of reference for a solution or an idea spark would be incredibly helpful!
Thank you!
~ Brandon
“For God so loved the world, that he gave his only begotten Son, that whosoever believeth in him should not perish, but have everlasting life.” - John 3:16 (KJV)
BrandonKastning is offline   Reply With Quote
Old 06-16-2020, 11:10 PM   #2
BrandonKastning
Wrench Re: 2001 Saturn L300 - v6 3.0 Liter - Fog Lights (Parking Ones)
FSM Troubleshooting + Technical Details:
Old 06-16-2020, 11:12 PM   #3
02 LW300
02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold
02 LW300's Avatar
2002 L-Series 2.2L Sedan
Default Re: 2001 Saturn L300 - v6 3.0 Liter - Fog Lights (Parking Ones)
I don’t think the 2001 has automatic headlights standard. It was optional until 02 when it became standard. My switch says auto/park/on. The base 2000-2001 switch says off/park/on.
My 02 has daytime running lights which burn the high beams in series so they run at 6 volts. All 2000-2002 models have orange lights outside of the headlights. They are also the turn indicators, dim for running lights and bright for turns.
Fog lights are optional on these models and have a switch on the dash just left of the hazard flasher switch. The fog lamps are very low and at the outside ends of the front bumper next to the lower grill. The fog lights when turned on only work with the low beams.
The sensor on top of the dash controls the hvac and the automatic headlights.
Again read your fsm.
2002 L200/5 Loaded, over 1/4 million miles!
Old 06-16-2020, 11:13 PM   #4
BrandonKastning
Wrench Re: 2001 Saturn L300 - v6 3.0 Liter - Fog Lights (Parking Ones) [SOLVED]
After reading some of the trouble shooting data; I realized the FSM continues to talk about a fog switch.
I found it and now I know what it does and it fixed my non-broken fog lights!
Glad it all worked and left some good knowledge too!
Cheers everyone!
Old 06-16-2020, 11:15 PM   #5
BrandonKastning
Thumbs Up Re: 2001 Saturn L300 - v6 3.0 Liter - Fog Lights (Parking Ones)
Fog lights are optional on these models and have a switch on the dash just left of the hazard flasher switch. The fog lights when turned on only work with the low beams.
02 LW300,
100% Accurate to what I just discovered! Thank you very much and I posted the FSM diagrams to assist others in the future also.
Glad to know you're 02 LW300 has auto fog lights though; nice feature!
~ Brandon
Tags
2001 l300 fog lights, l300 fog lights
2001 Saturn L300 - v6 3.0 Liter - Puller Fan BrandonKastning L-Series Tech 57 06-30-2020 03:17 PM
2001 Saturn L300 - v6 3.0 Liter - Broken Mounting Bolt BrandonKastning L-Series Tech 33 06-30-2020 10:03 AM
2001 Saturn L300 - v6 3.0 Liter - Seafoam in crankcase housing? BrandonKastning L-Series Tech 20 05-05-2020 08:37 PM
2001 Saturn L300 - v6 3.0 Liter - Won't stay running after a breakdown and bad... BrandonKastning L-Series Tech 502 04-25-2020 01:10 PM
2001 Saturn L300 - v6 3.0 Liter - STINGER Isolator 200 AMP + Auxilliary Power BrandonKastning L-Series Tech 28 03-14-2020 06:32 PM
