#1 |
I replaced my upper transmission mount (the dogbone), and I saw that the required torque is 37 ft/lb. The question I have is how far do you have to screw in the bolt to get there? The bolt head is starting to go into the rubber part, but when I check the torque with my torque wrench, it's only at around 20.
Does it screw in THAT much? I also noticed that the bolt is kind of at an angle, so will I need to unscrew it, and somehow bring my transmission forward? |
#2 |
![]() Join Date: May 2002
1995 SL2
I'm going to check my car, now.
> 95 SL 2 = 653,369 Miles 40.4 MPG, as of 5/20/11. My manual Radiator Fan Switch, courtesy of Wolfman's patient installation guidance, continues to be.......invaluable < The car was retired |
#3 |
Thanks. I meant to take a picture last night when I had my air filter/box off the car (changed the transmission fluid) but forgot my camera.
#4 | |
1995 SL2
It's what I thought.
The bolt, has incorporated into it's head, a washer. It is that washer, which is supposed to rest up against a metal sleeve, through which the bolt is inserted. With that said, the head of the bolt, does not rest up against any rubber. Is your collarbone, OEM (((>Original Equipment Manufacturer <))), or an aftermarket unit ![]() Quote:
![]() The base, into which the bolt is screwed, is at an angle -- it's been damaged.
#5 |
It's an aftermarket dogbone since I was stupid and forgot to get the part when I was at the dealership. And my car was in an accident, but a long time ago. But yes, it looks as if the bolt is going in at an angle.
#6 |
Try the procedure described here, but JUST do the "loosen" part. Then jack under the tranny a little, and see if it moves forward enough for the dogbone to line up with the hole in the frame.
#7 | |
![]() Quote:
#8 | |
![]() Quote:
#9 |
The upper trans mount should not have just ruuber anywhere the bolts go through it. The part at the trans should have a steel bushing and the part to the frame has an aluminum insert.
http://www.saturnfans.com/photos/sho...ze/big/cat/650 If your mount does not have these then you have a bad one.
A lousy day in paradise is still a day in paradise. |
Bookmarks |
Bad Swaybar/ upper srtut mount for 2003 Ion 3 | Mz.Italian Diva | Ion General | 22 | 05-07-2013 10:03 AM |
Bad Upper Motor Mount? | David R | S-Series Tech | 23 | 07-29-2008 10:50 AM |
Upper engine mount(torque access mount) | slv01sc2 | S-Series General | 21 | 08-26-2007 02:19 PM |
Torque Axis Mount (Upper Engine Mount) Problem | kickflipjr | S-Series Tech | 7 | 03-10-2006 03:28 PM |
Torque Axis Mount (Upper Engine Mount) Replacement | wolfman | How-To Library | 29 | 10-30-2005 04:00 PM |
