Old 08-04-2009, 11:01 PM   #1
mlambert77
mlambert77 is on a distinguished road
Question How long can I drive with a coke can gasket under my EGR valve?
I have a 99 SL2, 160k miles on it. Today after filling up, it started lurching and when I went below 1500 RPM the engine really bucked and eventually died. I had to put the car in neutral and keep the RPM's above 2000 at lights/stop signs.
I went to Autozone, they pulled the code and said bad EGR. I took it off so they could test it with a 9v battery, and sure enough, the pindle never moved.
I just watched this video http://www.youtube.com/watch?v=8YRq2Xl58Oo&NR=1 on how to check the EGR valve from Richpin, and he said to cut a coke can, and make a gasket and put it under the EGR and if it runs smooth, you know for sure. (at the 5:30 mark is where you'll see what I'm talking about).
My question: I don't get paid until next week. How bad will it mess up my car if I drive with the coke can gasket in between the EGR valve and regular gasket?
mlambert77 is offline   Reply With Quote
Old 08-04-2009, 11:16 PM   #2
Default Re: How long can I drive with a coke can gasket under my EGR valve?
You can drive that way until you get tired of the SES light. Eventually the hot exhaust gas will eat a hole through the can. That takes about a week.
You might want to invest in a can or 2 of carb cleaner and give that valve a good cleaning if the pintle will not move when you poke on it with a screw driver. It sounds like your valve is sticking open so a good cleaning will fix it, maybe. And, if you have an option between an aftemarket EGR valve and a good used one from a local J/Y go with the J/Y. You have to use an EGR from a 99 and newer car, the DOHC and SOHC are the same part.
Old 08-04-2009, 11:29 PM   #3
mlambert77
Ok, thanks. I normally drive about 15-20 miles a day, so a week is perfect really. I cleaned the pintle once this weekend actually, and then today this happened. I hope I didn't mess it up when I cleaned it last.
I sprayed it with some carb cleaner and used a toothbrush to brush it basically. Would it be better to spay some carb cleaner into a bowl and let the pintle soak for awhile?
Old 08-04-2009, 11:33 PM   #4
93SC2'in
93SC2'in is on a distinguished road
93SC2'in's Avatar
1993 SC2
what are the long term affects of driving without a operational egr or a blocked one? should be the question
93 SC2, 5-speed, <dead and gone>
95 SL2 5-speed, oem header, gsi TB, sprint 2.0, kyb gr2's, wb02, SAFCII, CAI, 17"s
Speed Kills - save lives, Drive a honda
93SC2'in is offline   Reply With Quote
Old 08-05-2009, 09:01 AM   #5
DonP
1995 SL2
Do you have to do an emissions test? That can be a limiting factor.
Old 08-05-2009, 09:31 AM   #6
rsg3
rsg3 is on a distinguished road
1999 SL
Isn't the '95-'99 valve the same part? They're the same number in RockAuto's catalog. The part number they list is different for '00 and up.
rsg3 is offline   Reply With Quote
Old 08-05-2009, 09:38 AM   #7
mlambert77
No, we don't have one here. I cleaned the pintle last night. I had cleaned it before, but never realized how to clean it thoroughly until reading about 40 posts on the topics here. It still shudders a bit when accelerating from a stop or around 40mph, but hasn't stopped at red lights/stop signs/etc yet. If it keeps up though, I might do the coke can test.
Old 08-05-2009, 09:55 AM   #8
If you like, stick two coins in place instead of the soda can gasket. The coins last longer.
And a few have left this blocking gasket, using coins or sheet metal, for long term blocking without any damage to the engine.
Old 08-05-2009, 10:00 AM   #9
mlambert77
Going to sound stupid, but any coins, or dimes (since they're thinner than nickles/quarters).
Old 08-05-2009, 10:38 AM   #10
I believe that 2 nickels were used. If you clean it it and it still does not function correctly block it off and see what happens. It is possible you have a different problem.
Old 08-05-2009, 10:41 AM   #11
You are right, 95-99 are the same, changed for the 2000 model and up.
coke can gasket, egr valve, richpin
Slow leaking valve gasket. How long??? Mgg4591 S-Series General 20 09-25-2009 10:43 AM
EGR Valve Gasket + sealant? and other ? AJT_Leo S-Series Tech 12 07-18-2007 08:08 AM
Long enough Valve Cover Gasket Cure TIME nmsaty S-Series General 17 06-09-2006 07:40 AM
EGR Valve Gasket Question SL1Joe S-Series Tech 9 01-14-2006 12:50 PM
How long to tell if EGR valve clean worked 07green1 S-Series General 2 04-05-2005 04:34 PM
