Old 08-14-2021, 09:48 PM   #1
BrandonKastning
BrandonKastning is a jewel in the roughBrandonKastning is a jewel in the roughBrandonKastning is a jewel in the roughBrandonKastning is a jewel in the rough
BrandonKastning's Avatar
2001 L-Series 3.0L Sedan
Question 2001 Saturn L300 - v6 3.0 Liter - ECU Question for someone! [Which Way]
Hey everyone!
I am re-assembling my L81 and have forgotten which way the ECU faces w/ it's sticker (rectangular sticker on the bottom right, I believe).
Could someone snap me a picture please? This way I know the correct way to install it and which connectors go into each slot. (It's been over 1 year almost).
I couldn't find anything in my threads.
Best Regards,
~ Brandon
Old 08-14-2021, 11:58 PM   #2
02 LW300
02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold
02 LW300's Avatar
Default Re: 2001 Saturn L300 - v6 3.0 Liter - ECU Question for someone! [Which Way]
Here is a picture.
File Type: jpg 6CC68092-95CA-488B-9F79-4020A33DD995.jpg (148.3 KB, 15 views)
2002 L200/5 Loaded, over 1/4 million miles!
Old 08-15-2021, 01:03 AM   #3
Hopefully the battery negative cable was disconnected before disconnecting the ecm cables to remove the ecm. Battery negative must be disconnected before reconnecting the ecm cables to prevent any electrical short occurring from reconnecting one or both connectors incorrectly. It's easy to put multiple pin connectors on incorrectly and bend/damage pins. At least two wires are live at all times when battery cables are connected for the ecm keep alive memory holding emissions parameters. When a reset is performed from a reader, battery cable disconnect or pulling ecm fuse, live power to memory is removed to erase it. Factory default parameters are used as the engine learns new parameters and written into memory while driving. Disconnecting battery negative before disconnecting or reconnecting the ecm and other electronics prevents live 12v on any wire from inadvertently connecting to an incorrect pin from misalignment when disconnection/reconnection occurs, possibly causing damage to a circuit.
In addition and just a guess on my part as I never disconnected my ecm, the two multiple pin connectors may be keyed to prevent them from incorrect matings. You'd have to examine each male and female connectors for either a metal or plastic pin that fits only into the female terminal with a mating hole or tabs around the plastic connector perimeter only fitting into its matched female terminal.
VCX NANO
Old 08-15-2021, 03:42 PM   #4
BrandonKastning
Thumbs Up Re: 2001 Saturn L300 - v6 3.0 Liter - ECU Question for someone! [Which Way]
02 LW300,
Thank you sir!
~ Brandon
Originally Posted by 02 LW300 View Post
Here is a picture.
ecu, l81
2001 Saturn L300 - v6 3.0 Liter - Water Pump Replacement (Coolant Question) BrandonKastning L-Series Tech 3 10-10-2020 04:40 PM
2001 Saturn L300 - v6 3.0 Liter - DNJ Engine Overhaul Kit - Anyone? BrandonKastning L-Series Tech 42 10-01-2020 02:03 PM
2001 Saturn L300 - v6 3.0 Liter - Puller Fan BrandonKastning L-Series Tech 57 06-30-2020 03:17 PM
2001 Saturn L300 - v6 3.0 Liter - VCX NANO vs. GM L81 (1 Hour+ Run) BrandonKastning L-Series Tech 38 06-26-2020 12:36 AM
2001 Saturn L300 - v6 3.0 Liter - Fog Lights (Parking Ones) BrandonKastning L-Series Tech 4 06-16-2020 11:15 PM
