Go Back   SaturnFans.com Forums > Models > Saturn Sky > Sky Red Line
Old 03-28-2021, 01:57 AM   #1
shsven18
shsven18 is on a distinguished road
Default I need help with P258B Vacuum Pump code
So I just got a P258B code on my 2009 Sky Redline and before I go and buy a new Electronic Vacuum Pump what is a common issue that would cause this code. also I am wondering where is it I could not find it when I popped the hood open.
shsven18 is offline   Reply With Quote
Old 03-28-2021, 08:36 AM   #2
Default Re: I need help with P258B Vacuum Pump code
Did you try searching here for past threads? Searched other Sky or Redline forums? A Google search may help too.
*One link to obd code definitions; https://www.obd2-code.com/2017/08/p2...rformance.html.
*Past thread; http://www.saturnfans.com/forums/sho...d.php?t=115018.
*Sky Roadster forum; https://www.skyroadster.com/threads/...-anyone.25431/
Old 03-30-2021, 12:16 AM   #3
shsven18
I went through them both neither or them helped me at all one was ends saying it was a recall and I called my local Buick dealer and it was fixed back in 2014 and the other thread goes nowhere.
I can't find the Electronic Vacuum Pump on my car does the Saturn Sky Redline even have one.
Old 03-30-2021, 10:22 AM   #4
Did you try searching other Sky forums for help?
If I'm not mistaken, the electronic vacuum pump may be used for power assisted braking. Conventional power assisted brakes use vacuum generated from the intake manifold as the engine runs. A dedicated vacuum port, vacuum hose and check valve connects to the brake vacuum boost unit behind the brake master cylinder. The brake vacuum boost unit is a large round black canister. If you are familiar with brake systems, underhood parts, brake lines m etc, then you should be able to trace the vacuum hose from brake boost unit to the vacuum source.
If unfamiliar with vacuum brake systems then try looking under the hood of another vehicle or ask where the vacuum brake hose routing exists. It's always between the brake vacuum boost unit and engine intake manifold port near the firewall, drivers side. Once you've seen the vacuum hose routing on conventional vehicles using engine vacuum, you should be able to trace your vacuum hose from brake boost unit to vacuum source. Only one hose exists, isn't shared with other miscellaneous devices requiring a vacuum source.
How about this $85 Vacuum Pump? AndreasChen S-Series Tech 9 05-24-2010 10:26 AM
How to use Vacuum Pump on AC alexyoung59 S-Series Tech 3 08-27-2009 12:28 PM
AC vacuum pump recommendation? Greg1 S-Series Tech 3 08-04-2008 07:54 PM
How to tes the EGR valve without using a vacuum pump turbobuick33 S-Series General 4 07-09-2006 09:30 PM
How to tes the EGR valve without using a vacuum pump turbobuick33 S-Series General 0 07-08-2006 03:59 PM
