Old 11-01-2021, 09:17 AM   #1
jimlrc5499
jimlrc5499 is on a distinguished road
Default Under Hood Relay Box
2004 Saturn Ion 2
I had to move the under hood fuse and relay box to replace my brake booster and master cylinder. I put everything back together and now when I turn the key all I get is a buzzing noise. I also get a "Power Steering" message on the instrument panel. I think either I damaged a relay or missed reinstalling a wire. Does anybody have a connection diagram for the box?
jimlrc5499 is offline   Reply With Quote
Old 11-07-2021, 11:21 AM   #2
Simcoewaters
Simcoewaters is on a distinguished road
2004 ION-3 Sedan
Default Re: Under Hood Relay Box
When my sons Saturn Ion 3 would not start ( I don't recall a buzzing sound) the info display flashed PWR STR & Coolant intermittently. I do not recall if the pass lock symbol was flashing. I do know that the DIC (display) was not reading "service vehicle". I preformed the reset procedure and the car started.
The reset procedure is as follows.
Turn the key as if to crank the starter
release the key
wait ten minutes ( I am quite specific on this time line. I don't know how much leeway is acceptable outside these time perimeters.)
turn the key to position off. If I recall I had to press the little button on the steering wheel column to get the key to this position. Hold the key in this position for ten (10) seconds
Repeat above procedure two more times. turn the key as if to start....
I hope this works for you if not I have other procedures that worked for me. This has been a periodic issue.
Simcoewaters is offline   Reply With Quote
Old 11-07-2021, 03:32 PM   #3
jimlrc5499
I'll try it. I have the PWR STR message.
Old 11-07-2021, 05:07 PM   #4
jimlrc5499
Didn't work. For some reason the drivers side fog light is staying on as well.
Bumper, Hood, hood latch damage robb_sc2 S-Series Tech 4 11-03-2015 12:11 AM
Hood release cable crimped, hood stuck in a released state Cards Ion Tech 3 01-06-2009 07:05 PM
DIY Article: Hydraulic Hood Struts - Replaces Hood Prop Rod Robman L-Series Tech 4 11-09-2008 03:50 PM
Hood was smashed.. need new hood.. spork L-Series General 10 02-29-2004 01:20 AM
FS: first gen sc2 hood... perfect for subie hood scoop conversion! BobDobbs Classifieds 4 04-28-2002 10:54 PM
