Old 06-30-2011, 02:42 PM   #1
surreyman
surreyman has a spectacular aura aboutsurreyman has a spectacular aura aboutsurreyman has a spectacular aura about
Default 02 SL1 front brake job: caliper piston dust boot question
I am replacing the pad and rotors on my 02 SL1 and have run into a problem. The first wheel went without a hitch. On the second wheel when I compress the caliper piston with a c-clamp the rubber gasket around the piston (piston dust boot) is not folding back the way it should. about 1/8 of it bulges out and I can't get it to fold back in properly. I had thought that there might be some air in the system so I bled the brake at this wheel and it still will not seat back properly. Can any one please tell me if this bulging gasket (dust boot) needs to be fixed and how so or is it ok to let it go as is?
surreyman is offline   Reply With Quote
Old 06-30-2011, 03:32 PM   #2
MikeH
MikeH is on a distinguished road
MikeH's Avatar
2000 SC2
Default Re: 02 SL1 front brake job: caliper piston dust boot question
I poke it in using something that will not put hole in it, like a popsicle stick.
MikeH
MikeH is offline   Reply With Quote
Old 06-30-2011, 05:22 PM   #3
surreyman
thanks for the advice. I tried to poke them back in with a Q tip but they keep popping out, like there is some air behind them so I do not know what to do next.
Old 06-30-2011, 05:55 PM   #4
rollin_96
rollin_96 is on a distinguished road
1996 SL1
You may want to buy a caliper rebuild kit for 7-8 bucks @ AZ.
It's pretty easy to do.
Tweaked FSM http://www.mediafire.com/?ofliygqpep460un
rollin_96 is offline   Reply With Quote
Caliper dust boot question/problem Tomvich S-Series Tech 3 02-21-2011 05:16 PM
Cracked Brake Caliper Piston Rod? mariopalumbo Vue General 5 02-17-2009 09:28 AM
Brake Job: Need help bottoming rear caliper piston kcbaltz S-Series General 5 04-27-2008 09:41 PM
Need guidance on caliper boot, rotor and pad wear, after brake job. Tiger S-Series Tech 4 05-18-2006 01:02 AM
02 Brake caliper piston sticking! Borisk Vue General 4 12-22-2005 01:25 PM
