Old 10-12-2018, 04:13 PM   #1
philsplace
philsplace is on a distinguished road
Default Bad ECM. Are they replaceable?
Hello,
I have had an issue with the engine fan on my 06 Vue 3.5L not shutting down. I was told that the ECM was bad but they did not know how to fix it because it was not supported by the manufacturer anymore.
Q: If i locate one from the same model year and engine size, can it be replaced? I have had not luck locating a new one. Any help would be appreciated.
Thanks
philsplace is offline   Reply With Quote
Old 10-12-2018, 04:44 PM   #2
waiter21
2003 VUE 2.2L
Default Re: Bad ECM. Are they replaceable?
ebay, junk yards
Old 10-12-2018, 05:09 PM   #3
PCF
PCF is just really nicePCF is just really nicePCF is just really nicePCF is just really nice
PCF's Avatar
Widely available.
But you have to have a dealer program it for you. This and other eBay sellers have VIN programmed ECM's for sale:
https://www.ebay.com/itm/02-07-Satur...2:pf:0&vxp=mtr
2005 Vue 2.2L FWD 5 speed
PCF is offline   Reply With Quote
Old 10-12-2018, 06:37 PM   #4
philsplace, who are 'they' that told you the ecm is faulty and 'they' don't know how to fix it? GM will happily empty anyone's wallet for any service whether a repair is successful or not. Under new car warranty, everything is repairable because of the warranty. Out of warranty simply means they can charge any price to support their dealership operation - high overhead costs passed onto customers. Independent repair shops with skilled mechanics and techs using aftermarket scantools can be less costly and still provide professional services. Unfortunately, many repair shops not investing in better talent and equipment become 'replacement artists', replacing things until solving a problem. Experienced repair shops are sometimes difficult to find.
There's some simple troubleshooting to determine why your cooling fan won't turn off. It may be as simple as a stuck cooling fan relay. Some engine computers have a default program - if the engine cooling system is faulty or the operating temperature falls below a certain value, default programming turns on the cooling fan to prevent any chances of overheating. Electronic temperature sensors are the only way engine computers know if an engine is freezing, warming up or overheating. Without a cooling system temperature sensor, engine computers have zero info to determine engine temps. A reader capable of displaying cooling system temps is a good way to see what actual operating temps are and help with troubleshooting.
As a rule, the majority of engine computers are fine. To deflect from inexperience, many will blame engine computers instead of attempting to determine why a cooling fan stays running.........
Old 10-13-2018, 08:55 AM   #5
philsplace
Originally Posted by philsplace View Post
Hello,
Thanks
Thanks for the response.
Yes, i have seen that the ECM for these model years are replaceable and can be flashed. Unfortunately, I have been unable to get a solid response on whether the the ECM for the 06 3.5L can be flashed.
Old 10-13-2018, 09:01 AM   #6
philsplace
Yes, i have seen that the ECM for these model years (2.2L) are replaceable and can be flashed. Unfortunately, I have been unable to get a solid response on whether the ECM for the 06 3.5L can be flashed.
The shop i used have always been fairly dependable in the past. I was told that they had contacted the local dealerships but knowone could tell them if the part could be replaced. Seems that the shelves are bare when it comes to this particular ECM. I was hoping if i found an ECM from the same engine and model year, that it could possibly be swapped without being flashed? Thank you all in advance
Old 10-13-2018, 09:24 AM   #7
RobertGary1
RobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to all
1996 SC2
Iím not following. Of course the EMC can be flashed. Thatís how itís updated and configured. If you have an mdi interface you can buy a single vin subscription for a year for around $40 from ac Delco and flash it yourself with the same software the dealer uses.
https://www.acdelcotds.com/acdelco/action/subscribehome
-Robert
Old 10-22-2018, 01:29 PM   #8
philsplace
I found a company that was able to fix the ECM without having to have it re-programmed. Sent in my ECM and it was returned 24 hours after they received it. The name of the company is G7Computers.
Thanks all for the responses
06 saturn vue, bad ecm, bad pcm, ecm, pcm
A/C Clutch - Replaceable or not SilverSaturn02 S-Series Tech 28 07-14-2019 09:11 PM
A/C clutch replaceable in car?? mitche Ion Tech 8 09-01-2016 12:58 AM
Wiring Harness Melted. Is it replaceable. . .? pmheart6 Ion Tech 9 12-01-2008 11:05 AM
'01 SL2...Is the odometer light replaceable? toofastforyou S-Series Tech 9 12-28-2006 02:17 PM
Is my Door Hinge Pin replaceable nmsaty S-Series General 4 04-12-2006 11:46 PM
