Old 11-15-2014, 04:29 AM   #1
johnSW2
johnSW2 is on a distinguished road
2001 SW2
Default 2001 SW2 Ignition Issues
Hello Everyone,
My name is John and this is my first post. Trying to solve my car's problems so my wife won't make me get rid of it. Its a green 2001 SW2 in decent shape. Love it, great gas mileage +33 and great utility.
Anyhow, here is the starting/ignition issue:
First off, the ignition switch is wonky, it takes the unsuspecting person excessive jostling of the key to even get it too turn, separate from the steering wheel lock. Just FYI. Though I will be replacing the lock cylinder soon. Hopefully that fixes this issue.
But the larger starting issue is this:
If I turn the ignition key lightly (as though not really paying attention) the car will start just fine, however the starter motor remains engaged with the engine running. Almost as if you were to be holding the key down too long. And if I immediately shut the engine off, I can still hear the starter motor running. When this happens, if I turn the key again, kind of like a double turn of the key, the starter motor will flip off and everything is fine. As if the surge of voltage from the key engaging again clears the system (obviously not the right wording but the result is the same.)
However, if when starting the car, if I give the ignition a firm turn no problems at all and I drive on my merry way.
After this had been happening for some time, like maybe 2 months (before I figured out the double-key turn), the issue happened, I eventual got the engine and starter off but was unable to restart the car, lights and radio on but no "click", no engagement with the starter. So obviously I thought I killed the starter motor. (novice mechanic) So I replaced it. Which didn't fix the problem. So I checked the fuses - and I've also blown the 30 amp fuse in the engine compartment fuse box. Once I replaced this fuse, it started right up. Only less then a week later, the "starter motor staying on" issue showed right back up again, which is right about when I figured out the double-start trick.
Long story short, the starter motor was probably fine, so why am I blowing 30 amp fuses, and why does the starter motor occasionally stay engaged if I gingerly turn the ignition key.
Any thoughts? Thanks guys!
John
johnSW2 is offline   Reply With Quote
Old 11-15-2014, 09:22 AM   #2
Default Re: 2001 SW2 Ignition Issues
Just a guess but both the lock cylinder and possibly the actual ignition switch are worn out. Before it breaks you want to replace the lock cylinder.
https://www.youtube.com/watch?v=8iLPpXVElU0
https://www.youtube.com/watch?v=Yt8wnj4qHoc
These 2 videos are for an earlier model but give you an idea of what is involved.
Ignition switch and housing pictures.
http://www.saturnfans.com/forums/sho...9&postcount=50
Lock keying
http://www.saturnfans.com/forums/sho....php?t=182379#
You can buy a new cylinder kit and key it to match your key.
The first thing to do is get a dealer cut key that is made from your VIN number, the local grind it out hardware store key will not work, Chevy dealer only.
Old 10-31-2015, 07:30 PM   #3
johnSW2
2001 SW2
So new developments...The problems continued after I replaced the ignition switch. The result, a blown out starter. This time a shop looked at it. They cut a new key and replaced the starter but didn't find anything else wrong. So now the key turns well.
Two months later, all the same problems again. And now the new starter is blown again. And really, these started right back up again with in about three weeks after the repair.
What could be the electrical issue here? What is causing the starter to draw too much current, blowing the fuses, and now blowing the starter...again?
A mechanic friend has looked at it and he too is finding nothing wrong.
Any thoughts?
Thanks in advance,
John
Old 11-02-2015, 07:12 PM   #4
spacetrace33
spacetrace33 is on a distinguished road
spacetrace33's Avatar
2000 SL1
I really hope you find the solution, messed up situation that needs answered. Which could help out others.
00 SL1 Daily Driver Frankenstein
98 SL2 race car-not street legal by any means
01 SC2 race car-not street legal by any means
00 SL2 aka boom boom pow
spacetrace33 is offline   Reply With Quote
Old 11-02-2015, 07:46 PM   #5
More detail on the fuses that are opening and more info on "blown" starter.
Which fuses and exactly what is happening to the starter.
Old 11-02-2015, 09:20 PM   #6
billr
As mentioned before, probably both the ignition lock and switch were worn. You just replaced the lock, correct? Now go back in and check out or replace the switch.
Old 11-02-2015, 09:40 PM   #7
TomM96
TomM96 has a spectacular aura aboutTomM96 has a spectacular aura about
Either component , if 'shot' could cause the starter motor to remain engaged long enough to blow fuse (or 'burn out')
I would imagine drops of oil on the lock cylinder might fix That , but new Ignition Switch needed most likely.
Old 11-03-2015, 01:23 AM   #8
johnSW2
2001 SW2
Clarifications,
- new ignition switch, not the lock cylinder
- had a new key cut from the dealer, the old one was way worn down
- 30 amp fuse is the one that burns out, the large green one one the right side of the box (or closer to the passenger compartment) see image
- "how does the starter burn out?", it will no longer engage with the engine, simple spins, meaning I can here a whirring but the engine is not turning over. The shop that previously "fixed" the problem had the new key made and replaced the starter which got it up and running again, but didn't solve the original issue of the starter occasionally staying engaged and thus burning out fuses, which as a result, eventually lead to the starter going bad as it has again.
- I do have a new lock cylinder to install, and have watched richpin's video but have been unable to remove the existing cylinder, I will try again, seems like this is the current theory as to the problem source, do you agree?
Old 11-03-2015, 08:53 AM   #9
Look in the cover and postr exactly which fuse that is.
The starter running and engine not cranking is usually a bad-unfixable starter. If you are buying starters from a local parts store you are buying overpriced JUNK. Try here, http://www.dbelectrical.com/p-1009-n...02-satrun.aspx This is NEW and it fits. You pick your shipping but USPS is dead slow.
That fuse is not causing the starter failures.
Old 11-03-2015, 12:35 PM   #10
billr
Sorry about misreading, transposed "lock" for "switch"; but verdict is the same: replace the other part now.
Alas, the switch might have been OK, I think that is why you were advised to replace the lock first...
Old 11-03-2015, 02:48 PM   #11
johnSW2
2001 SW2
Hi OldNuc, thanks for the tip and the cheap parts I'll definitely look that up.
In my previous post I posted an image pointing to the exact fuse which is burning out, so please take a look there. Also, I realize that the fuse is not the issue but rather a symptom of something else. And it is that something else which I am trying to track down, also, the blown out starter is a symptom of the problem as well. Could it really be the lock cylinder causing the short? I am not understanding why that could be the case. Just looking for a little more info here. Thanks for all the advice it is much appreciated.
Old 11-03-2015, 05:05 PM   #12
billr
I (we?) are not proposing that the lock cylinder causes a short. Rather, the worn lock does not move the switch fully back to the "run" position when the key is released after starting. This leaves the starter still energized, all the time, and ruins the starter as well as overloading the fuse that was only intended for intermittent operation.
Old 11-03-2015, 06:09 PM   #13
You will have to remove the fuse box cover and look at the diagram molded into the lid and then post the actual ID of the fuse. These fuse box layouts are generic 91-02 and they tend to year uniqueness. You are asking for detailed information regarding what is most likely several problems and if you want an intelligent answer then you are going to have to provide some information.
Old 11-04-2015, 12:26 AM   #14
johnSW2
2001 SW2
Hi thank you all for the responses. I very much appreciate your time and expertise!
billr - thanks for the explanation regarding the lock cylinder, this makes much more sense now, and being that the issues do seem very well linked to the nuance with which I turn the key - definitely my next culprit
OldNuc- I believe the fuse is the IGN4 fuse, I'll have to double check in a day or so when I can make it out to my friend's house to check.
Old 11-04-2015, 12:38 AM   #15
johnSW2
2001 SW2
Since the car is not at my disposal at the moment, I found the diagram on line, it's the
IGN 3 fuse, see image here
Definitely replacing the lock cylinder this weekend too...
Old 11-04-2015, 08:57 AM   #16
I will look at the drawing later today and post back what I find specifically.
IGN-3 feeds the ignition switch and the heater blower motor. That is all.
The ignition switch feeds IGN-3 to the following:
RUN - I/P Panel HVAC and Rear defog relay power to the window heater, ABS traction control, I/P switch.
CRANK - Starter solenoid.
If this fuse only opens when the starter is being cranked then the various loads should be selectively isolated and the starter solenoid wiring inspected between the starter and the ignition switch.
Is this a manual or automatic?
Old 11-04-2015, 03:34 PM   #17
johnSW2
2001 SW2
an automatic
Old 11-04-2015, 05:08 PM   #18
There are a few more parts in the auto crank chain
You mentioned that the starter will run but it does not turn the engine over. Is this still the case? Where exactly are you getting replacement starter from and who is installing it?
fuse, ignition, starter, sw2
new ignition cylinder issues 2001 S series gbc_15 S-Series Tech 1 01-28-2013 11:25 PM
2001 SL1 ignition r4monsters S-Series Tech 10 07-15-2012 01:17 PM
2000 LS1 ignition/fan issues away8907 L-Series Tech 14 05-28-2012 09:14 PM
95 SL2 DOHC ignition issues Dopeyz S-Series General 22 04-02-2011 11:03 PM
Ignition issues, no SES Titanium48 S-Series Tech 0 04-30-2007 08:17 PM
