Old 08-13-2009, 08:47 PM   #1
mlambert77
mlambert77 is on a distinguished road
Question Did MMO soak and have more white smoke than before?
I have a 99 SL2 and last weekend I did the MMO soak. I started it Friday night, and ended up being dragged to a wedding Saturday, so the MMO actually sat for about 24 hours. Put the rags in, started it up, put them back in and started them a second time. Started the car and drove it around the block and there was some white smoke, but not that much.
Then came home and changed the oil, which was the blackest I had ever seen it. The past few days though, I've had a lot of white smoke. More smoke than I had before. I checked my oil levels and everything is still good, but I can't figure out why so much smoke.
Trying to figure out why it's smoking more now than before. Maybe I need to change the oil again?
mlambert77 is offline   Reply With Quote
Old 08-13-2009, 08:59 PM   #2
dorisSL
dorisSL is on a distinguished road
dorisSL's Avatar
1995 SL
Default Re: Did MMO soak and have more white smoke than before?
*sometimes* carbon build-up can act as a mask on another problem. for instance, i once had a car that was getting crummy gas mileage. i ran some injector cleaner through it, which did clean the injectors. problem was there was buildup on one injector that was acting as a plug on aa leak in that injector.
just a thought. personally, i'd give it good long drive (but close to home ) and keep an eye on oil and coolant levels, and monitor the smoke.
1995 SL, born 12/23/94, manual, WAI 190,500, "Doris"
(I'm Ben, the car is Doris)
you can't mulch at those speeds man, that's too fast
dorisSL is offline   Reply With Quote
Old 08-14-2009, 04:01 PM   #3
Skyshatter
Skyshatter is on a distinguished road
White smoke usually isn't Oil related. It's coolant that's leaking in and being burned. If it's persisting after the MMO and not going away I'd start watching the coolant really closely to see if it's leaking out.
Skyshatter is offline   Reply With Quote
Old 08-16-2009, 02:16 AM   #4
S3aturnR
S3aturnR is a jewel in the roughS3aturnR is a jewel in the roughS3aturnR is a jewel in the rough
S3aturnR's Avatar
1996 SL2
1999 SL1
you put something into your car's engine that had the word, "mystery" on the label and you expected positive results?!
s3aturnr
"reno is a lot like maybury, except everyone's on crystal meth and prostitution's legal" - junior
S3aturnR is offline   Reply With Quote
Old 08-16-2009, 10:13 AM   #5
groingo
groingo is on a distinguished road
White smoke is never a good thing, pop your oil filler cap and check for a milky white residue, check your fluid levels and pull your spark plugs and check for rust deposits on the electrodes.
If it continues it sounds like a head gasket is getting ready to unload, but if not then just keep driving it and see what happens, may just be residue from the cleaning solution.
94 Saturn SW1 (Cash for Clunkers Reject....no kidding)
96 SL2 (Rescued)
groingo is offline   Reply With Quote
mmo, mmo soak, smoking, white smoke
MMO Soak #2 - Still No Smoke azn_redneck S-Series Tech 20 11-21-2006 08:38 PM
No Smoke After MMO Soak azn_redneck S-Series Tech 2 10-25-2006 12:34 PM
did mmo soak...white smoke continuously? illogicalmethod S-Series Tech 13 09-26-2006 08:34 AM
Why don't I see smoke out the tail pipe when I do the MMO piston soak turbobuick33 S-Series General 15 05-11-2006 07:00 PM
MMO piston soak (and soak, and soak...) David 93 SL2m S-Series Tech 9 02-19-2003 11:51 AM
