Old 04-22-2006, 07:35 PM   #1
agoldslsaturn
agoldslsaturn is on a distinguished road
agoldslsaturn's Avatar
Default painting /priming the plastic
Quick question before im going to the auto shop (come on i just spent a ton of money at mall lol, cant afford to not buy something for my car too!)
I am going to take off some of the panels in the car tonight and sand them to see how they look painted black. My question is, there are many varities of sand paper/sand sponges, etc.
So, can I get a primng sand sponge? Do I need to wet sand? Should i wipe down the plastic with alchol first to remove some of the "oily type base" and then sand? Wash the plastic after wards? Im going with a can of Krylon Plastic paint, do I need to get a primer also? Primer made just for plastic?
How bad will the sanding affect my texture?
Anyone have tips besides a slow even spray and leave it flat to prevent drips? Im kind of doing this in the dark because its cool out and I cant take the heat right now...
Thank you
Cause when push comes to shove
You taste what you're made of
You might bend, till you break
Cause its all you can take
agoldslsaturn is offline   Reply With Quote
Old 04-22-2006, 07:40 PM   #2
GreenSC2
GreenSC2 is on a distinguished road
GreenSC2's Avatar
Default Re: painting /priming the plastic
Thank you
DO NOT DO THIS. The paint that is used for these panels (and bumpers) has a special flex agent in it to keep it from cracking after it drys. Joe shmo or Krylon or whatever spray can crap that you have will just make a cracked mess in the long run. DON"T DO THIS....................
It's not easy being Green(SC2). (IntelliTXT SUCKS)
I refuse to be a Lemming!!
GreenSC2 is offline   Reply With Quote
Old 04-22-2006, 07:48 PM   #3
andy_95sl2
andy_95sl2 is on a distinguished road
andy_95sl2's Avatar
i love how you raped your shift key while typing, green!
i asked a similar question, and yes you have to use a primer that is plastic-friendly because most primers eat plastic.
why dont you do it the easier/cheaper way and just get a roll of vinyl "skinz" stuff and just cover the entire panel with that to see how it looks, then remove it when you do in fact, paint it?
2004 Jeep Wrangler Rubicon -> daily & toy =)
2009 BMW 128i -> sold
2003 VW GTI 1.8T -> wrecked
1998 Saturn SL2 -> parted out
1995 Saturn SL2 -> sold
andy_95sl2 is offline   Reply With Quote
Old 04-22-2006, 07:49 PM   #4
agoldslsaturn
Im sorry! I meant to clarify....
Its the panels inside the car, the fuse panel, drivers side kick panel and I believe the console is what I am going to do tonight...
I didnt mean to mean the outside panel, I would never do those myself, I have a buddy who will do those in exchange for some food and beer and a bit of money...
Is the skins for inside or outside?
Im doing the INSIDE, sorry for confusion.....
Old 04-22-2006, 07:51 PM   #5
andy_95sl2
andy_95sl2's Avatar
OH that changes everything.. all you gotta do is use a little bit of adhesion promoter (or primer) and then use spray paint. If you want to use Krylon Fusion, you dont need a primer, just use clear coat when you're done
Old 04-22-2006, 07:52 PM   #6
eRic 02sc2
eRic 02sc2's Avatar
Saturn S-Series are finished with a basecoat/clearcoat paint system. it consists of an immersion primer on all steel and space frame components, a spray-on primer on all composite panels, and a high solid waterborne basecoat and catalyzed urethane clearcoat.
edit: I just read that you meant the inside bits.
Saturn does not recommend painting soft PVC parts. Rigid or hard ABS and PC plastics require no primer. Conventional interior acrylic lacquers adhere satisfactorily. 1. wash the part with mild soap and warm solution to remove any waterborne contaminants. 2. rinse the part thoroughly with clean fresh warm water and dry off. 3. wash entire panel with PPG D846 multi-prep cleaner or equivalent to remove any surface contaminants. 4. thoroughly dry the panel before the multi-prep cleaner evaporates.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 04-22-2006, 07:56 PM   #7
agoldslsaturn
xsaturnx-Im going to have to use something though, because I tried one panel earlier and the paint did not adhere well. Its a semigloss black, I dont want high gloss but I dont want a flat color either...
How well does that adheision promoter work? have you personally used it and it worked fine? I dont have a problem with doing it the "right" way to make sure its done right. I am eventually going to do whole car black inside with dark tint so I want it all to look good. I have painted lots of things before, including a plastic little tykes thing, but this plastic is totally different...
Old 04-22-2006, 07:58 PM   #8
GreenSC2
GreenSC2's Avatar
Use simple green or other good cleaner to remove any buildup that would make the paint not stick. There are a few good posts where people have succesfully dyed interior parts. You may want to consider that option. Paint has a bad habit of chipping and peeling and not covering well on interior panels. It may look really bad and then you are stuck with it.
Why would you want black interior in Florida??
Old 04-22-2006, 08:00 PM   #9
agoldslsaturn
I cannot use a stripper to strip it? I dont know if I am fond of the dyes honestly...
Because I am psycho??? Nah, I hate the tan inside, it looks really crappy with the car and because my seats are all black now it looks even worse...
Old 04-22-2006, 08:21 PM   #10
andy_95sl2
andy_95sl2's Avatar
RalliArt16 used adhesion promoter on his wheels before clearcoating them. Its basically a clear primer thats safe for everything.
Old 04-22-2006, 08:26 PM   #11
cindy_and_lee
cindy_and_lee is on a distinguished road
cindy_and_lee's Avatar
1995 SC1
hey goldie... go to walmart in the HOUSE paint section where they have all the spray cans... look for the BLUE can(can't remember the name brand) and find one with EQUIPMENT GRAY (PRIMER) on the label... wipe down the interior (or exterior, it works just the same) with some alcohol or paint thinner... then shoot it with that primer.... let it sit for a few minutes and it will turn dull... then shoot your color... you'll like the results...
don't listen to the bs about flexible panel and crap... our WHOLE saturn is painted with spray cans..... YEAH, spray cans... unless you look real damn close you cannot tell that it has been... I've kicked the crap outta the saturn and NONE of the paint has flaked off yet....
So.... FLEXIBLE AGENTS MY ASS!!!
Lee
cindy_and_lee is offline   Reply With Quote
Old 04-22-2006, 08:38 PM   #12
andy_95sl2
andy_95sl2's Avatar
CindyandLee, i think that because the paint on your car isnt that old, it didnt get a chance to chip. The flex agents keep it from chipping in the years to come.
Old 04-22-2006, 08:57 PM   #13
cindy_and_lee
1995 SC1
it's 1995 factory paint underneath the green... BUT most of the gold was taken off the car... some parts of the car have been painted for about 2 months now... we painted the car as money permitted....
oh yeah, we painted with CERAMIC engine paint... so i doubt it will ever chip... if it does it'll chip in a sheet not just small spots....
Lee
Old 04-22-2006, 09:36 PM   #14
andy_95sl2
andy_95sl2's Avatar
you didnt take the panels off when you painted it, did you? i see a LOT of overspray, but thats no biggie, just get a clay bar and it'll take off the over easily.
Old 04-22-2006, 11:58 PM   #15
cindy_and_lee
1995 SC1
hell no... no panels removed... too much work are you crazy?? lol
we just taped off the emblems and windows and painted...
not worried about the overspray right now... we just driving it and enjoying the looks we get right now... when i actually get back to work and start making some money we gonna hit the entire car with about 1000 grit paper and spray it again.... then we gonna clear coat it, maybe with some sort of pearl...
Lee
Old 04-23-2006, 01:09 AM   #16
agoldslsaturn
Thanks Lee,
I bought that stuff, adhesive promoter, 120 sand paper, a sanding tool thingamabob, gloss finish and black gloss.
Tomorrow will be fun fun fun! i have to do some major school work first so the car might not get done yet.
Old 04-24-2006, 11:42 AM   #17
RangerRover
RangerRover is on a distinguished road
RangerRover's Avatar
1999 SW2
120 grit is probably too much... i would use 1000 grit or maybe even 2000 if all you are doing is prepping the surface. 120 will deeeeeply scratch the plastic, so unless you are planning on removing the texture, go with something higher.
You can tell Linux is made by geeks.
RangerRover is offline   Reply With Quote
Old 04-24-2006, 11:51 AM   #18
agoldslsaturn
Well I cheated...
I sprayed primer on it, the sprayed the krylon fusion on it. IT turned out ok I guess. Im not sure I want the high gloss that it has though...
I think I will try the flat and then spray with gloss to see if that looks better. Ill take pictures later tonight.
Old 04-24-2006, 11:55 AM   #19
itsmesillybubba
itsmesillybubba is on a distinguished road
itsmesillybubba's Avatar
2006 ION-3 Quad Coupe
Originally Posted by cindy_and_lee
....So.... FLEXIBLE AGENTS MY ASS!!!.....
Give it some time and it will chip....then it is going to look ghetto......
Don't be lazy
...we just driving it and enjoying the looks we get right now...
They might be looking at you for a reason different from what you think....
Friendship is like peeing your pants, everyone can see it, but only you can feel the true warmth.
My 95 SL1 is gone :(
itsmesillybubba is offline   Reply With Quote
Old 04-24-2006, 02:01 PM   #20
sps SOHC
sps SOHC is on a distinguished road
sps SOHC's Avatar
I've used Krylon Fusion and can't say much about it. Except for PRIME FIRST! The instructions are retarded and it will end up scraping off really easy if you don't prime.
On another hand, I saw this thing on TV (as 3 of my 12 channels are infomercials) about this spray gun that is electronic and has very little overspray. I can't remember what it was called but it seemed to do a pretty good job and might work well for painting interior panels. Anybody know what I'm talkin about?
-96 SC2 gets 35 mpg mix city/hw.
sps SOHC is offline   Reply With Quote
Painting Lower Gray Plastic to Match Routs Vue General 13 10-26-2007 09:12 PM
Painting Plastic Fenders on 2002-2005 VUE m4gician How-To Library 1 07-22-2006 04:01 PM
Painting PRE 06 vue (02-05) BUMPERS and plastic FENDERS...has it been done? m4gician Vue General 4 06-11-2006 10:24 PM
Lifter Priming? gmschrank S-Series Tech 2 05-17-2005 11:20 AM
Painting Interior Plastic Crazyquick23 S-Series Mods 4 02-28-2003 12:15 AM
