Old 05-05-2006, 04:18 PM   #1
TIMSPEED
TIMSPEED is on a distinguished road
TIMSPEED's Avatar
1998 SW2
Default Switching from R-12 to R-134a: Just need the adapters right?
Well..not JUST the adapters...but Right now, I have completely replaced all my o-rings with the Saturn OEM parts (got them FROM saturn)
I HAD a full charge of R12 in there, and it was nice and cold..but it leaked out because my high/low side valve's leak. SO, since I can't get anymore R12..I just need to get those adapter fitting thingies right, and put them on...vacuum it down to suction, and then add R-134a, right?
AmazingHL, isn't that what you did? Easy like that?
TIMSPEED is offline   Reply With Quote
Old 05-05-2006, 04:43 PM   #2
amazinghl
Default Re: Switching from R-12 to R-134a: Just need the adapters right?
I actually changed the both hoses to R134a style. Everything bolted up fine.
00 Insight 72mpg
Old 05-05-2006, 04:49 PM   #3
TIMSPEED
TIMSPEED's Avatar
1998 SW2
Well, you did that instead of changing the valve's...but since my hoses are good, and I feel comfortable doing the valves, it's just that easy right?
Old 05-05-2006, 05:16 PM   #4
eljefino
eljefino's Avatar
1995 SW1
follow the directions on the retrofit box.
You probably need to vacuum the system and do some other stuff too.
Just b/c the r12 leaked out doesn't mean something else didn't leak in... like water.
1994, AC....134a?? saturn94v S-Series Tech 1 10-05-2008 10:55 PM
wheel adapters Garrick S-Series General 2 03-14-2008 09:08 PM
R-134a converesion 93 SC2 DukeCitySC2 S-Series Tech 1 04-18-2006 11:05 AM
antenna adapters defy69 Ion General 0 10-26-2005 06:17 PM
'92 SL2 Converting A/C to 134a Alex's Dad S-Series Tech 7 09-04-2002 08:22 PM
