Old 07-25-2005, 03:06 PM   #1
frog8546
frog8546 is on a distinguished road
frog8546's Avatar
Default Brake Caliper Bolt Torque
I just replaced pads & rotors on My '96 SL1, anyone know what I need to torque my caliper bolts to?
frog8546 is offline   Reply With Quote
Old 07-25-2005, 03:35 PM   #2
Qlara
Qlara's Avatar
Default Re: Brake Caliper Bolt Torque
Hope I recall right, it's around 27ft-lb for each Cal bolt.
For pads replacement only, you only need to take out the LOWER bolt, the Cal can flip up. (Don't kink the brake hose).
Qlara is offline   Reply With Quote
Old 07-25-2005, 03:37 PM   #3
Low Saturn
Low Saturn's Avatar
2007 AURA XR
81 ft. lbs. or 110 Nm
Thats the info I have with me at work. I would have to double check with the FSM when I get home.
Old 07-25-2005, 03:37 PM   #4
frog8546
frog8546's Avatar
Thanks, I tried calling the dealership, but they won't even let me talk to a tech.
Old 07-25-2005, 03:50 PM   #5
Qlara
Qlara's Avatar
No way the Caliper bolts are torqued that high!
Are you talking about S-series here? :o:
It should be around 27ft-lb range.
Imagine the Wheel Nuts are torqued at 104 ft-lb.
Old 07-25-2005, 03:53 PM   #6
frog8546
frog8546's Avatar
27 ft-lbs sounds right, but it felt like 81 trying to get them off
Old 07-25-2005, 04:03 PM   #7
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Yeah, after I read it and typed it, I kinda questioned the amount. It sure as heck feels like it when you remove them though. I think the info I found might of been referring to the caliper bracket to hub assembly torque.
Old 07-25-2005, 05:19 PM   #8
FrozenPilot
FrozenPilot's Avatar
81ft-lbs sounds like the caliper bracket to hub bolts.
Its all about the coffee...
'06 Mazda 6i & '95 Saturn SL1
FrozenPilot is offline   Reply With Quote
Old 07-25-2005, 05:41 PM   #9
frog8546
frog8546's Avatar
Yeah, that's what it was - thanks again for your help!
Old 07-25-2005, 09:21 PM   #10
S3aturnR
S3aturnR's Avatar
1999 SL1
you are correct, sir!
caliper support to steering knuckle bolts = 81 ft/lbs
caliper guide pin bolts = 27 ft/lbs
looking at the 96 s-series tech manual now. (not the haynes or chilton, but the manual that the saturn techs use)...
s3aturnr
Seized brake caliper bolt. Eliot S-Series Tech 28 09-25-2011 03:22 AM
Front Brake Caliper Bolt specs tfgorman S-Series Tech 9 01-17-2008 10:17 AM
Front brake caliper bolt torque specs bassplayrr Vue Tech 7 12-26-2006 05:42 AM
2004 V6 AWD caliper bolt torque specs? fgwinn Vue General 4 05-06-2006 10:13 PM
L brake caliper bolt size s3nfo Miscellaneous Tech 4 01-11-2004 11:07 AM
