Old 01-09-2022, 03:47 AM   #101
lanxer57
lanxer57 will become famous soon enough
1999 SC1
2001 SC1
Default Re: specifics on compression testing, P0301
No problem with the spark plug wires than? What else could cause these codes? Should I reset and see if these codes come back? (Because I can not drive it very much)
1997 V6 Mustang coupe 2018-2019(wrecked, airbags went off)
2001 SC1 2020-2021(wrecked, frame was bent)
1999 SC1 2021-now(working progress)
lanxer57 is offline   Reply With Quote
Old 01-09-2022, 02:58 PM   #102
billr
I saw no problem with the routing, but have you checked the plug wires for resistance and shorts? Neither is likely to cause that P0340, however.
Yes, reset the code and see if it comes back, and how soon.
That entire CMP sensing system consists of the plugs, plug wires, ICM/coil module, PCM, and wiring from the ICM to PCM (including connectors). The plugs are new and gapped at about .040", correct? Swap the #1-4 coil with the #2-3 coil, see if that prevents the P0340. Next, check the ICM-PCM wiring for any obvious physical damage, including unplugging every connector in the circuit to inspect for corrosion or damage, and to "wipe" the connector contacts to clean off any minute corrosion that may not be visible. Check for corrosion where the ICM mounts to the engine.
Still no joy? Putting in a known-good ICM is probably the next step. This can be kind of tricky, though, since an ICM from a FLAPS or on-line vendor cannot be assumed to be "known-good"...
Old 01-10-2022, 11:51 PM   #103
lanxer57
1999 SC1
2001 SC1
I blocked the EGR valve wit 2 pieces of a soup can smashed together. I did not feel a leak, and dad did not smell one. these were rough circles about the size of a quarter. None of the codes went away while idling. (P0172, P0733, and P0340) I will try resetting the computer tomorrow to see how long they take to come back. STFT was about 20%, and LTFT was about -14% with the EGR blocked this seems to be an improvement over the last readings I took. I checked the oxygen sensor readings again, and S1 was oscillating between 0.35-0.8 volts while S2 was oscillating between 0.1-0.45 volts, later 0.1-0.65 volts. Would a blocked EGR cause emission test failure itself? It sounds like something that would do that...
Old 01-10-2022, 11:59 PM   #104
billr
Yes, I would expect the blocked EGR to cause a fail in two ways: it will probably increase the tail-pipe NOX above limits and it will probably set some more EGR-related codes. Let's see what codes you get after a reset.
I think you are going to have to check the injectors for leakage.
Old 01-17-2022, 06:19 PM   #105
lanxer57
1999 SC1
2001 SC1
I can not test drive it again until the next time dad takes me to a junkyard. brake fluid is slowly seeping out of the passenger side rear drum brake wheel cylinder, and dad knows about it, so he will not let it leave the driveway. Are the wheel cylinders the same across all s series with drum brakes of all years? Are they different on DOCH models? Should I convert it to disk brakes if I can find them? (I live near mountains, and drive automatic trans)
In other news, P0340 came back while idling with EGR blocked.
This thread seems to be getting a bit off topic, Is it possible to rename a thread?
Old 01-17-2022, 10:09 PM   #106
lanxer57
1999 SC1
2001 SC1
I switched the ignition coils among other things and reset the computer. none of the codes have come back after 30 minutes of idling. STFT was -30% and Ltft was 18% before it reached operating temperature. STFT later changed to -18%.
How accurate id the intake temperature sensor supposed to be compared to outside weather? 46F read as 72F when warming up and later as 122F. Is the RPM supposed to drop when the fan or headlights turn on? Just something I noticed.
Old 01-20-2022, 07:55 PM   #107
lanxer57
1999 SC1
2001 SC1
P0340 came back again almost immediately as soon as I started the engine today. Could the blocked EGR have something to do with that? I only saw that code after I blocked it.
I also noticed something else: When the gas pedal is pressed or let go, the oxygen sensor voltage increases to 0.8V before tapering off after a few seconds and returning to oscillating. STFT also goes to 0%, when the throttle position changes, before tapering off in the same way back to -30%. The TPS works, there is nothing wrong with it. Does this mean anything?
Old 01-20-2022, 09:45 PM   #108
billr
Blocking the EGR passages should set some codes, but I would not expect P0340 to be one of them. Put the EGR back to stock and see if the P0340 goes away. Then block/unblock it again a few more times, to see if that is a repeatable symptom.
Can you summarize what effect, if any, blocking the EGR has made on fuel trims? That was the main reason for suggesting blocking the EGR, to see how it affected trims.
You are using live-data to check the TPS? Does the live-data show injector pulse duration?
Old 01-21-2022, 01:10 AM   #109
lanxer57
1999 SC1
2001 SC1
I have used live data to check the TPS, it works smoothly as the pedal is pressed. The cheap scanner that I have does not show duration if fuel injector pulse. With the EGR blocked, the fuel trim seems to have gotten closer to 0, which I believe is supposed to be normal, but I have never seen it reach 0 at idle. Codes usually seem appear when the vehicle is moving, but it can not move until the brakes are fixed, as the right rear wheel cylinder has developed a small leak. I am considering converting to rear disks if I can find them, because I live near the mountains.
Old 01-21-2022, 01:31 PM   #110
billr
My opinion? Do not bother with the conversion to rear discs.
Old 01-21-2022, 07:37 PM   #111
lanxer57
1999 SC1
2001 SC1
Will drums be okay even when I am driving down a mountain? There are lots of mountains about 20 miles west of where I live. Big ones, with lots of hills and corners. I am not a very good driver, and would like to keep major accidents to a minimum. I should also figure out if a SOCH with an automatic can even get up those inclines...
Old 01-21-2022, 08:34 PM   #112
billr
Hills don't matter much, you should be down-shifting to use engine braking. It is more important how you drive. If you try for a smooth driving style, so as to maximize fuel economy, ride comfort, and safety; then braking is "light duty" even on hills. If a full-performance stop is needed for some emergency situation, then drums will handle that (one essential stop) every bit as good as discs. However, repeated heavy use of brakes, like in road-racing, will tend to overheat drums so that they fade and decrease in performance. Are you going racing with this beast? If so, I guess it will only be down-hill racing, since you already know it is under-powered for going uphill.
You need to get this back in a drivable condition, so you can pursue the engine issues. A wheel cylinder is only about $10, little loss if you later feel the urge to brag that you have rear discs and want to convert.
Old 01-21-2022, 10:34 PM   #113
lanxer57
1999 SC1
2001 SC1
I was thinking I would get wheel cylinders and shoes even if I do manage to find a saturn with disks, just in case such a conversion failed. In my little experience, redundancy is never a bad thing...
Old 01-22-2022, 11:37 PM   #114
lanxer57
1999 SC1
2001 SC1
After unblocking the EGR, I started it, and P0340 was gone and it did not come back as it was idling in the driveway. It was still running rich, STFT -30%, LTFT -17%. No codes appeared in the 30 minutes it was idling. I can not go to the junkyard this weekend, because moms exhaust is leaking again, and being a usable car, it gets priority. maybe next weekend, depending in dads mood.
Old 01-25-2022, 08:27 PM   #115
lanxer57
1999 SC1
2001 SC1
I blocked the EGR again, and P0340 did not come back, so I do not know what caused that but I just hope it stays fixed. I am going to unblock the EGR again, because I am trying to pass an emissions test. I will not be able to visit the junkyard this weekend, because dad is tired of seeing error codes on moms 2010 traverse, and we will be trying to fix that instead because it actually matters, unlike my S series paperweight. I might get to work on it again at some point.
Old 02-23-2022, 01:52 AM   #116
lanxer57
1999 SC1
2001 SC1
I switched out the brakes, test drove it, and the SES light came back on with P0172, P0733, and P0340, should I try changing oxygen sensors next?
Old 02-23-2022, 02:05 PM   #117
billr
Clear the codes and see if the same ones consistently come back. Do this at least five times, making no changes. We need to have some confidence those are the only true codes now.
As to chasing them, I would go after the P0340 first, as it should be the easiest to solve. That has been discussed before; it has to be the ICM (includes coils), wiring, or plugs, plug wires, or ECM. Which of those parts have you checked now, and how?
Again, don't do anything until you clear codes and get them to repeat consistently.
Old 02-23-2022, 04:40 PM   #118
lanxer57
1999 SC1
2001 SC1
I tried switching the coil towers, inspecting, and cleaning everything including spark plugs and wires, coil towers, and any connectors. I think I should bring a gas can because the gauge reads empty. I filled it halfway a few months ago. no point in checking oil level on our steep driveway.
Old 03-05-2022, 03:33 AM   #119
lanxer57
1999 SC1
2001 SC1
P0340 has disappeared again. P0172 came back after 30 seconds of driving. P0733 came back a few seconds later and I actually felt it slip this time going maintaining a speed of 25MPH.
Old 03-15-2022, 10:14 PM   #120
lanxer57
1999 SC1
2001 SC1
P0172 is gone. it is no longer running rich. I replaced bad fuel injectors with more bad fuel injectors. I just put some more in, and it runs better. I also messed with the oxygen sensor and need to replace it. I will start a new thread for my transmission problems.
How-To: Compression testing w/ engine out of car ShawnV How-To Library 6 10-14-2010 11:42 PM
2001 SOHC P0301 - confusing compression numbers BobbyBeans S-Series Tech 44 05-24-2010 11:34 AM
compression testing results Amp67 S-Series Tech 3 05-27-2009 01:54 PM
Testing Compression in an S-Series Saturn-Eh! How-To Library 20 10-13-2005 03:54 PM
Compression and Leak Down testing. Red97sc2 S-Series Tech 2 04-09-2004 02:37 AM
