Old 02-02-2013, 04:16 PM   #1
hedgehog
hedgehog is on a distinguished road
Default front hub and bearing replacement?
Is it possible to replace these without taking the front end apart? For example just pop the hub and bearing out then put back in? I figured I would ask the experts! Thanks.
hedgehog is offline   Reply With Quote
Old 02-02-2013, 04:32 PM   #2
Default Re: front hub and bearing replacement?
There are tool kits availible to pull the bearing with the steering knuckle in place. I suspect that they work well when things are not rusted but are difficult when they are rusted up.
Old 02-03-2013, 03:48 AM   #3
el diablo viejo
el diablo viejo's Avatar
1994 SW1
The bearing/hub assembly needs to be pressed out and pressed into the knuckle, which means the knuckle has to come off unless you have the special tools. The going machine shop rate is about $25 per knuckle for the press work. Some of the better local parts stores also have machine shops so you can get it all done in one location.
97 sl2 a/t 104 K
Front wheel bearing replacement OMG !!! rowdydog Vue Tech 18 06-19-2013 12:45 AM
2004 Front Bearing Hub Replacement with ABS BlueHeron Vue Tech 4 07-30-2012 07:03 PM
Front Strut Bearing Replacement todd8 S-Series Tech 3 01-04-2007 03:07 PM
front wheel bearing replacement help.. 1993 S-Series Tech 2 06-23-2006 10:37 PM
Front Wheel Bearing Replacement '01 SC1 tacoguy S-Series Tech 20 12-14-2004 11:55 AM
