Old 11-23-2012, 01:25 PM   #1
guami007
guami007 is on a distinguished road
Default Window Track - 2000 SW2
As some of you know, the window up/down assembly on these vehicles tends to come off the track which renders up/down window functions inoperable. The reason for this is mainly due to a POS plastic clip that glides on the track but that also holds the 'ball' part of the up/down assembly in place on the window track. These plastic clips tend to break which causes the ball to pop out of the plastic clip which causes the up/down assembly to come off the track. I just fixed mine in about 20 minutes using a hitch pin clip from home depot. The link below shows 3/4 but I used 5/16. A total of .56 cents and 20 minutes time. I believe GM sells the plastic clips for about $20 and the near certainty that the plastic clip will break in the future. Hope this helps anyone with similar issues.
http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
guami007 is offline   Reply With Quote
Old 11-23-2012, 08:45 PM   #2
toggenburg
toggenburg's Avatar
Default Re: Window Track - 2000 SW2
My 2 rear windows were off track since I bought the SW2 2.5 years ago.
They would slip down a few inches and had to be shoved up for them to 'stay' for a while. Using the down/up buttons would never bring them back up.
My kids got in the habit of shoving them down to gain access to the locked car.
Now, just today, without looking, I depressed the left rear window down button instead of the drivers's one....the window went down a ways.
I pressed UP and it returned UP and stayed tight.
Weird.
I now remember that it has been about a month or more that these 2 windows have not needed to be manually pushed up.
Must have gotten back on track, tho I have not ever opened the read door panels to check what was wrong.
I will keep your pin idea in mind for a permanent repair.
Old 11-24-2012, 02:03 AM   #3
taatman
taatman is on a distinguished road
taatman's Avatar
Can you please post a pic on how this works? Gret idea. I remember doing this repair on past Cadillac Fleetwood's I owned. I would use a c-clamp to pop them in.
96 SC2 - 137k - AUTO.
94 SL2 - 200k? + 2nd owner AUTO
taatman is offline   Reply With Quote
Old 11-24-2012, 11:59 AM   #4
guami007
Best that I can do considering tight quarters.
Window track LouieG119 S-Series Tech 5 07-13-2009 01:11 PM
Window off track Bogel S-Series Tech 2 05-15-2008 04:47 PM
window off track on a 95 SC2... DJboozeAlot S-Series Tech 9 05-04-2006 10:49 PM
Back Window out of track bhwalds General Saturn Discussion 0 10-17-2005 06:12 PM
Window track problem LoveMySaturn S-Series Tech 1 01-23-2003 10:16 PM
