Old 08-04-2010, 01:07 PM   #1
ucantcme57
ucantcme57 is on a distinguished road
1993 SC1
Default 1993 SC1 Idle Adjustment
Hello All..
I have a 1993 SC1 4cyl TB w/PS w/A/C
It is currently idling around 500rpm's and this idle is quite rough..
If the car was idling around 900-1000rpms it would be alot smoother..
Is there a way to adjust the idle up?
She burns alot of oil and I have to have an antifouler on cyl 1..
Please help..
1993 Saturn SC1 SOHC 5spd, A/C, Power Steering - 202,000 on the od..
ucantcme57 is offline   Reply With Quote
Old 08-04-2010, 01:58 PM   #2
Default Re: 1993 SC1 Idle Adjustment
Was the idle always this low? What's the idle rpm during cold engine start ups? If not above 1000rpm's then it may be a faulty/dead idle air control valve.
Old 08-05-2010, 05:33 AM   #3
WingsOfSaturn
WingsOfSaturn's Avatar
No way to physically adjust the idle. Lightly tap the idle air control with the handle of a screw driver to see if your idle changes.
97 SL2 AT 150K Original Owner
95 SL2 MT 220K+
My Saturns have BRASS ones!
Old 08-06-2010, 12:29 AM   #4
ucantcme57
1993 SC1
I have swapped the IAC before, no change cleaned that passage hole too... When u start the car idle 1200 - 1500 then slowly drops over time. Once coolant 1/4 hot, idle sits around 500rpms... I actually thought about putting a few washers between the cable and the gas pedal.. just something... just barely laying your foot on the gas pedal will put u in the 900 - 1000 rpm range.. Between an old egr and old IAC idle was 2000 but swapped those and idle came down. swapped Iac for another one but idle did not increase
Old 08-06-2010, 04:58 AM   #5
The coolant temperature at 1/4 is incorrect and may be a sign that the original coolant sensor (the two-wire one) was never replaced? Your '93 has two coolant sensors, a single wire one for the temperature gauge and a two-wire one for the pcm (engine computer). Either the coolant sensor is faulty or the connector is because the signals are low voltage and high resistance from a failed sensor or corroded connector alters signals making the pcm think the engine is still cold, as reflected on the temperature gauge. there's also a worn out thermostat that can run cooler than normal and may have to be replaced too. Once both are taken care of the temperature gauge should show 3/8ths needle deflection and possibly correct the low idle.
The replacement coolant sensor is brass.
Idle adjustment? wolfehunter S-Series General 28 12-28-2008 06:11 PM
Idle Air Control - adjustment question ? cboss S-Series General 4 10-27-2008 08:51 PM
minimum idle speed adjustment?? PitchBlackSC2 S-Series Tech 4 09-14-2006 11:45 AM
idle adjustment shaner123 S-Series General 5 01-05-2006 02:22 PM
VTi Idle RPM Adjustment coming? Laurence Vue General 4 12-31-2002 12:45 AM
