Old 05-17-2010, 08:21 PM   #1
shawnw_13
shawnw_13 is on a distinguished road
Default Can Bus Adapters
Hi Everyone,
Been searching through forums and what not to hunt down specific for adapters and what not and could not find exact specifics on what i needed so i will post my questions and sorry if this has been covered before.
I just recently purchased a JVC deck and got the standard GM wiring harness for it. After a few painstaking hours i realized that the red "12v" wire does not actually output 12v and from what i have read u need a adapter to properally interpert this signal. so what can bus adapter would i need (a part number and manufacturer would be great) and do i just wire this adapter inline with the standard wiring harness or does it replace it all together?
Next as for steering wheel adapters, has anyone successfully installed one if you could let me know what one used ( again part number and manufacture would be fantastic) thanks for the help
Shawn
shawnw_13 is offline   Reply With Quote
Old 05-22-2010, 10:56 PM   #2
pwise952
pwise952 is on a distinguished road
pwise952's Avatar
2008 Astra XR
Default Re: Can Bus Adapters
Originally Posted by shawnw_13 View Post
Hi Everyone,
Shawn
So this has been covered, but I think I can answer your questions anyway. The preferred CAN-BUS adapter is made by a company named Connects2 and can only be imported from the UK.
The part number is:
Connects2 SVX002 CANBUS adapter
You will also want to purchase the Connects2 JVC Lead for SVX002. This will give you full use of your steering wheel controls, and will also allow you access the "settings" menu and change the time on the clock.
Both of these items can be purchased from InCarExpress.co.uk . I believe people have had good experiences with them.
You will also need a radio antenna plug adapter, but those can be purchased easily at any electronics store or amazon.
As for the wiring, the Connects2 harness will connect directly into the Astra's wiring harness. On the stereo side, you will either need to splice the Connects2 to the stereo cables, or purchase a JVC to ISO cable, as the Connects2 supports ISO cables.
Hope this helps!
2008 Red Saturn Astra XR 5 door - 5 Spd
17" Saab 9-5 Alloys, Boomerang Armrest, DVD/NAV
pwise952 is offline   Reply With Quote
Old 06-07-2011, 01:12 AM   #3
zarrell
zarrell is on a distinguished road
Figured I'd bump this thread rather than start a new one. I am putting in a jvc deck and have figured out all the other parts I need (single DIN faceplate adapter, antennae adapter and the connects2 part) except the wiring harness. The above poster said he got the standard GM wiring harness, but I have no idea which one that would be. Can someone point me in the right direction. Thanks.
zarrell is offline   Reply With Quote
Old 06-11-2011, 10:31 AM   #4
phatfire6
phatfire6 will become famous soon enough
phatfire6's Avatar
2008 Astra XR
Do you have steering wheel controls? It makes a difference on what you will need.
phatfire6 is offline   Reply With Quote
MP3 USB Adapters? HELP PLEASE! aurific General Saturn Discussion 10 07-19-2008 08:23 PM
wheel adapters Garrick S-Series General 2 03-14-2008 09:08 PM
Switching from R-12 to R-134a: Just need the adapters right? TIMSPEED S-Series Tech 3 05-05-2006 05:16 PM
antenna adapters defy69 Ion General 0 10-26-2005 06:17 PM
Sandwich oil adapters hawthorne Mods and Performance 3 01-07-2002 10:33 PM
