#1 |
Easier said than done sadly. Who else here has gone though this and now drives around on a welded pin?
After seeing more than one pointless pin failure, even sometimes because of the stupidest reason. There is no reason the pin should ever fail, but they do. I've seen so many of them fail, that I've had it with them and their failure rate, and always having to baby the car, never spin the tires, don't drive it too hard, or the pin may pop! No more! I'm going the WELDED PIN ROUTE. It'll be nice knowing the pin is welded, having that extra insurance inside the transmission, it'll basically take that ticking time bomb, and be rid of it! I should note that this transmission came from a different car, and my pin is perfectly fine still, but I would rather have a welded pin. I scrapped the transmission in the picture, and kept the differential. So it begins, the era that I won't have to worry about my pin popping anymore. Everything has gone good and smooth so far. I took the differential to a local fabrication shop, where all the guy does is welding. I like the results, he followed though with all the details I gave him on welding the pin in, that it needs to be flush with the carrier, not to melt the bushings, and to tack weld the new roll pin I hammered in to the differential. From start; (56K warning) ![]() ![]() The Welding: ![]() ![]() ![]() ![]() I think he did a damn good job with the welding, and keeping it flush to the carrier. Nothing was melted. I'm happy with his work, he'll see more of my business for sure. Now, to get the car in the garage, get the transmission out, and get this differential installed in to it. Stay tuned, more to come!
"The Homecoming King" Saturns Saved: 18 Saturns Owned: 2 1999 SL2 HCE 175K 1994 SL2 HCE 135K 1999 SL2 Silver 125K |
#2 |
![]() ![]() ![]() Join Date: Feb 2005
1999 SC1
welded my pin before doing manual conversion on the sc2. SC1 still has un-welded pin. If it goes, I'll just pick up another trans & get the pin welded before installation. Not worth it to me to weld it as a preventative measure.
SaturnSeries.net owner |
#3 |
![]() Join Date: Apr 2005
1993 SC1
1996 SC1
After hearing so much about this, I'll likely keep the trans from my '93 as a spare. It's odd though, the '93 took a LOT of abuse when I got it and I never had a problem. I suppose it's just one of those "luck of the draw" things...
1996 Saturn SC1 -5spd Daily Driver 1993 Saturn SC1 -5spd RIP 1.28.2010@290,549km 1985 Chevrolet Monte Carlo SS -5.7L/SShaker Hood/WCT5 5spd 1970 Pontiac GTO -Judge Recreation/YZ RAIII400/M20 4spd |
#4 |
![]() ![]() ![]() ![]() ![]() Join Date: Apr 2008
1997 SL
Great photos- thanks. I might have mine welded this summer, I will have time to pull it apart etc.
Couple of questions. 1. Does the heat that the welder will apply damage other components in the carrier? 2. Except for welding, what is the cost to R&R the differential, are there gaskets to buy? I thought RTV is used between surfaces. 3. What would the welding cost be? Assume a local racer/mechanic with a small shop. Thanks! ![]()
97 SL. Bought 7/07, reluctantly sold Dec 2019 Burgman 400- indestructible beast Sportster 883- fun bike Cannondale 29er- daily driver |
#5 | |
![]() Quote:
We've got pretty go at it too. From the time the tranny it set on top of the work bench to tightening the last bolt after reassembly is about 40 minutes.
Mike -1991 Turbo SL2. 11.809 @ 116.488 mph www.differentracing.com -2001 Limited Edition SC2 (#78) -2001 Chevrolet Suburban -2007 Saturn Aura XR -2011 Rally Yellow Chevrolet Camaro 2SS RS |
#6 | |
1999 SC1
![]() Quote:
2. As long as all your seals, etc are good, a tube of RTV and some new trans fluid should be your only other costs. The trans uses an anaerobic sealant, but RTV works perfectly fine as well (I used RTV, has been perfect for about 4 yrs now.) 3. Totally depends on the shop. The shop I took it to charged $30, but then screwed up the bushing (as mentioned above). You might find some that are cheaper than that, you might not, totally depends on the shops in your area.
#7 |
After i saw the photos, I have to wonder if the hole for the spilt pin could be drilled out and tapped to recieve the pinion shaft retainer bolt out of a 7.5" Ford rearend? Yes the retainer bolt may have to be shortened, but maybe? It word save alot of grief when welding.
Just thinking............. |
#8 | |
1999 SC1
![]() Quote:
#9 |
Crap they make it looks easy on paper but once you actually get in to it, its far from easy.
I'm a bit more than half way complete on the entire job. But I have a welded differential pin installed in my Saturn now, sure feels good to know I won't have it pop on me anytime soon now. I did cut some corners to save some time since I didn't feel like going though the whole process. 1. Didn't remove the hood 2. Didn't drop the sub frame all the way 3. Didn't even bother removing the right side tire. 4. Didn't remove the exhaust pipe. 5. Didn't remove the trans stiffener plate. No corners were cut on the installation of the new differential in to the transmission.
#10 |
1999 SC1
People have managed to still pop welded differentials, so don't take it as an excuse to beat on the trans.
#11 |
![]() Join Date: Apr 2004
2008 Astra XR
Had a '99 SC2. About 18000 miles it spun the 2 & 3 rod bearings. When the dealership pulled it apart, they found the input shaft seal was leaking oil onto the clutch. They also discovered the pins were working their way out, so they replaced the diff, clutch and bottom end of the engine. Fortunately they covered it all under warranty!
So much for having fun with that car. When the lease ended, it was gone! I'm glad to see that I wasn't the only one with any of those problems.
Rex 2008 Astra XR 5 dr, 5 spd, sport package Black Sapphire If you're going to wave, use all your fingers. |
#12 | |
1999 SC1
![]() Quote:
#13 | |
![]() Quote:
I finished it, took it out for a little beat on it ride, went home, checked the transmission, A-OK. Back to my normal driving routine.
#14 |
1997 SL
"1. Didn't remove the hood
2. Didn't drop the sub frame all the way 3. Didn't even bother removing the right side tire. 4. Didn't remove the exhaust pipe. 5. Didn't remove the trans stiffener plate." 1-nope, don't need to 2-only need to drop the left side a few inches 3-don't have to touch any of the rt. side suspension nor axles 4-Seems you have to drop it (at the header), so the subframe can drop, the ex. pipe routes under the SF- Hmmmm 5-Nope R&R of a tranny is not that bad. Fortunately. And a lot of shops don't know the easy way! Go figure. ![]()
#15 |
![]() Join Date: Mar 2009
1994 SL1
well while yer in there cant ya put in a posi unit? i know in older rwd cers you can repace the spider gears with ones from a posi unit/limited slip(what ever ya wanna call it). is there a way to do that to our cars?
1994 SL1 - R.I.P. 1997 SL2 - sold :) 1978 El Camino - still fixing... 1999 I30t - daily driver 2007 Cag Daytona - fixing "Gimmie a Pickle jar, I'll open that B***h up like a MotherF**ker!" |
#16 |
1999 SC1
If you can hunt down an out of production quaife and want to pay $1,500 for it.
#17 |
![]() Join Date: Jan 2009
1993 SC2
Bookmarks |
Former Saturn Owner Struck by "Unresponsive" and "Inattentive" Treatment from Toyota | Charlie | General Saturn Discussion | 20 | 02-25-2011 05:11 PM |
Vin "7" Vin "8" Vin "9" brake pads/rotors universal? | demoncamber | S-Series Tech | 4 | 09-09-2009 12:35 PM |
Do all older Saturns "RUST" under that plastic "THINGY" that sits under the door???? | Token | S-Series General | 21 | 09-08-2005 10:14 PM |
Does "People First" Go with "Sex Appeal" ? Another blunder in the making? | saturnfreak01 | General Saturn Discussion | 15 | 03-12-2004 07:38 PM |
Im starting to think "Saturn" will be switched to "OPEL" by 2010! | johnsocal | General Saturn Discussion | 12 | 10-28-2003 03:05 AM |
