Old 03-08-2010, 06:18 PM   #1
Seanmu25
Seanmu25 is on a distinguished road
Default Valve body? Or..?
2002 Saturn SC1
I recently made my first post, and received a lot of help. Thank you.
Determined that I needed a new intake manifold gasket, which I will replace. It made me start to think...
I started reading more and more posts, and more How-to's. I came across the "reverse slam", and "valve body".
The problem I am getting is this:
The car has a very very slight slam into reverse, only when first warming up. The car shifts up just fine. However, it seems to forget to down-shift while braking, until less than 10-20mphs. The car will get a surge of RPM (normally 2500RPM) then drop back down to the normal 1900RPM.
Is this a cause of the vacuum loss? Or, is it something else - like the valve body?
And once it has reached 5-8mph, and I am braking the following happens: While downshifting into the "1st gear", the car will get a "crunch" from the driver side tire location.
My buddy told me that is probably from a warped rotor. What do you guys think?
Thank you in advanced for your insight and help.
Sean
Seanmu25 is offline   Reply With Quote
Valve Body??? gaeducator S-Series General 3 11-07-2009 09:47 PM
Valve Body Manual Valve Interchange Question acman S-Series Tech 2 11-05-2009 10:40 PM
new valve body motu56 S-Series Tech 5 03-31-2009 03:31 PM
Valve body 97 SL2 toddslaw S-Series Tech 9 08-13-2008 11:50 PM
Valve Body Orlando S-Series General 1 01-11-2005 09:36 PM
