Old 01-25-2009, 06:13 PM   #1
jpstoner
jpstoner is on a distinguished road
Question throttle body mod
i've been doing some looking around and I was wondering. when you bore out the throttle body (please correct me if i'm using the wrong term; i mean: http://www.qksltwo.com/tb.html ) i've read you are supposed to get a slight hp boost. My question is will it increase, decrease, or do nothing to your gas milage?
I purchased a $40 CAI off ebay and i think it gave me a small boost but dropped my milage by about 2 mpg. So will this also drop my milage or what can I expect?
Thanks in advance!
jpstoner is offline   Reply With Quote
Old 01-25-2009, 06:50 PM   #2
Default Re: throttle body mod
You have to feed all of those new ponies, there is no free lunch unless you increase the efficiency of the combustion process.
Old 01-25-2009, 07:41 PM   #3
WingsOfSaturn
WingsOfSaturn's Avatar
Does this mean my $25 Speed Chip off of ebay does not give me free power?
Just kidding!!!!
97 SL2 AT 150K Original Owner
95 SL2 MT 220K+
My Saturns have BRASS ones!
Old 01-26-2009, 01:55 AM   #4
jpstoner
makes sense. thanks
Old 01-26-2009, 02:06 AM   #5
black98dohc
black98dohc is on a distinguished road
black98dohc's Avatar
Do the TB mod if you want, and don't worry about 1mpg?? Just go for it, will increase your reaction and maybe 1hp
1998 SC2 - 92' header, Cat-back, CAI, Wires and plugs, Intrax lowering kit, Strut bar, LUK clutch, Just polished, Short shifter & Dojo™ knob
Coming up: Meet up on the 25th.
black98dohc is offline   Reply With Quote
Old 01-26-2009, 08:18 PM   #6
SC2Sick
1995 SW2
skip the porting and get a geo storm throttle body
sixthsphere.com owner
2002 Saturn SC2 - RHD
Old 01-26-2009, 08:23 PM   #7
Yeah, the Storms SOHC TB is larger then ours can be bored to and the DOHC TB is larger still.
Old 01-26-2009, 10:55 PM   #8
Fox Slaughter
Fox Slaughter is on a distinguished road
Fox Slaughter's Avatar
In all reality unless you are boosting or trying to make some good power, TB isn't going to do much for you. Except increase throttle response.
Fox Slaughter is offline   Reply With Quote
Old 01-27-2009, 01:49 AM   #9
black98dohc
So any metro TB will be a directly swap? Same hoses, same screws and all that? I saw a geo metro when i got the 92 headers on the junkyard. Here are the pics
I'm doing the bore at home, then SRI
Old 01-27-2009, 02:14 AM   #10
technical_dir
technical_dir is on a distinguished road
2000 SC1
thkx for the link very cool
technical_dir is offline   Reply With Quote
Old 01-27-2009, 01:04 PM   #11
PurdueGuy
PurdueGuy's Avatar
1999 SC1
Where did anyone say Geo Metro? Storm =/= Metro.
The storm tb will bolt up, the TPS & IAC either plug in or splice in, and the throttle cable requires a custom bracket.
SaturnSeries.net owner
Old 01-27-2009, 01:26 PM   #12
black98dohc
Storm then, sorry
Old 01-27-2009, 05:06 PM   #13
Fox Slaughter
As PurdueGuy said, you will need a custom throttle cable bracket. As the Storm I believe is back farther then out stock location. Or vice versa can't remember exactly.
Old 01-27-2009, 05:38 PM   #14
LOL, I was wondering about what kind of performance parts y'all were wanting to pull from a 3 cylinder 1.3 liter engine
I test-drove a Storm when they first came out, and came this close to pulling the trigger on buying one. Kinda glad I didn't, seeing how they seem to have held up over the years.
Old 01-27-2009, 05:48 PM   #15
black98dohc
I'll check the sizes and see what i can do, otherwise i will open up my own, but do it throught the whole TB, not like others do, bore till the butterfly or door, thats not a mod. You need to fully open the ID of the TB to let it better flow
Old 01-27-2009, 08:24 PM   #16
Fox Slaughter
People bore out both sides of the TB to the butterfly plate. You can't bore out around the TB plate because obviously the plate wont fit snug.
Old 01-27-2009, 09:15 PM   #17
PurdueGuy
PurdueGuy's Avatar
1999 SC1
If you remove material around the throttle plate, your car will never idle right again unless you replace it with a larger throttle plate. It also doesn't help to port the throttlebody out on the backside any more than to match the intake manifold.
Old 01-28-2009, 11:52 AM   #18
black98dohc
Of course i will not leave the stock plate if i'm doing the full ID bore. And i'm also matching with the intake manifold size. I've done this to both of my friend's civics and they worked good.
Old 01-28-2009, 01:07 PM   #19
RBrown20
RBrown20 is on a distinguished road
RBrown20's Avatar
1994 SL
Are either or both of those both of those direct fit? I have an sohc, and any lil bit will help.
Where the fug is my mirror?
~No Regrets, Just Life Lessons~
I need more speakers
94, SL, 250k+, manual trans, no power anything, sparkplugs, exhaust, CAI, steering wheel, FLUX CAPACITER!!!!
RBrown20 is offline   Reply With Quote
Old 01-28-2009, 01:18 PM   #20
PurdueGuy
PurdueGuy's Avatar
1999 SC1
That is for the dohc, not sure about the sohc, but you would still need the custom bracket for the throttle cable.
Throttle sticks - not throttle body - help! dannysm213 S-Series Tech 2 12-10-2006 05:20 PM
throttle body how far? irondiezl3 S-Series Tech 1 11-12-2006 10:40 PM
Throttle body mod newt Mods and Performance 13 06-13-2002 06:46 PM
ground effects / body mod Elmo Miscellaneous Tech 3 10-02-2000 07:20 PM
ground effects / body mod Elmo Suggestion Box 0 09-29-2000 04:15 PM
