#1 |
![]() Join Date: Feb 2008
You can disconnect all electrical connections to your transmission(don't drive or rev the motor) and you will have reverse if your valve body and shaft nuts and tubes seals are good. If you have reverse slam/no reverse after Wolfmans reverse slam fix and after replacing the valve body and new shaft nuts, then your transmission is bad. No need to mess with the transmission's electrical. Thanks to all for trying to help....
Bookmarks |
Reverse Slam Valve Body replacement Reverse Fork | MichelleG | S-Series Tech | 16 | 04-06-2009 06:48 PM |
Will reverse slam or new valve body fix this? | chevy57 | S-Series Tech | 0 | 12-26-2007 11:18 AM |
Had Reverse-Slam did Valve Body Replacement | lcd60 | S-Series Tech | 1 | 12-13-2006 07:59 PM |
new valve body-no reverse | Nowhere Man | S-Series Tech | 29 | 08-02-2006 10:28 PM |
Help me find reverse/valve body fix! | jasons56 | Miscellaneous Tech | 3 | 04-08-2003 01:11 PM |
